586,521 active members*
3,353 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > **BEST PLUNGE ENDMILL FOR ALUMINUM??**
Results 1 to 7 of 7
    Jun 2012
    19
    Post **BEST PLUNGE ENDMILL FOR ALUMINUM??**
    I have a straight up question!, What is a the best end mills for plunging out corners of a pocket in 7075-T6 Aluminum?? I have tried a few brands of 2 flute solid carbide endmills and from I have read, 2 flute seems to be the best but cant find any recommendations on brands, flutes, coatings, etc?
    Any info would be great,
    Thanks!
    Apr 2004
    5741
    Re: **BEST PLUNGE ENDMILL FOR ALUMINUM??**
    Try a drill-point endmill or drill-mill: 2 Flute Carbide Drill Mills - MariTool ; most endmills have a flat end, which isn't good for plunging even if it is a center-cutting design, which many are not. Coatings can help, but aren't essential.
    Andrew Werby
    Website
    Jun 2012
    19
    I ordered some 2 flute carbide drill mills and will give it try when they come in and post the results. Thanks for taking the time to help me out, greatly appreciated!!
    Dec 2007
    2134
    Whichever ones you get, avoid the gold TN coated ones as aluminium generally tends to stick to the coating and really gums up.
    cheers, Ian
    Oct 2012
    32
    Ooops! (Deleted)
    Oct 2012
    32
    Re **BEST PLUNGE ENDMILL FOR ALUMINUM??**
    I agree with everyone so far good advice! Donno about anyone else but I have had alot! of luck when dealing with 7075 using TiALN (black coated) 3 flute .030 corner radius solid carbide endmills with a 60 degree helix. Dont necessarily need the corner radius but it does help.
    I know the tight twist of the flutes helps chip evac quite a bit. Not sure wile plunging altho maybe give it a shot. I get alot of chatter with 2 flutes when plunging, So I always have used 4 flutes to plunge until I tried thos tight helix 3's and I'll never use another one agian. Damn near all around those seem to be superior on aluminium to all others I have tried.
    Nov 2014
    12
    Re: Re **BEST PLUNGE ENDMILL FOR ALUMINUM??**
    Quote Originally Posted by Nissan20det View Post
    ... g TiALN (black coated) 3 flute .030 corner radius solid carbide endmills with a 60 degree helix. ...
    Where'd you buy these? What brand?
  1. Can you plunge an endmill longer than the cutting edges?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2012, 01:53 PM
  2. 1mm Endmill in aluminum
    By JuicyBurger in forum Material Machining Solutions
    Last Post: 02-28-2012, 05:48 AM
  3. how fast do you plunge into aluminum?
    By Mini Beast in forum Taig Mills / Lathes
    Last Post: 08-29-2009, 09:56 AM
  4. Plunge cutting indexable endmill
    By orionstarman in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2008, 01:50 AM
  5. 1/32 Endmill cutting aluminum?
    By DennisCNC in forum MetalWork Discussion
    Last Post: 12-27-2005, 06:22 AM
