586,604 active members*
3,704 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Prolight 1000 Retrofit Newbie
Results 1 to 15 of 15
    Oct 2014
    9
    Hi all,
    I am brand new here and am really excited to have found such a great resource for information. I am a high school teacher that has an Intelitek Prolight 1000 mill. Recently, the proprietary PCI card that came with the mill died (as diagnosed by Intelitek ). I have been doing tons of research and learning in regards to retrofitting these mills. From what I understand, the mill itself is pretty hardy and built to last. Unfortunately, the card replacement from Intelitek is $695.
    With that kind of budget, I've been looking at retrofitting with this:
    Deepgroove1 Gecko control box
    Sounds like the Gecko 540 is the way to go and upgrading the steppers would add to the life and performance of the machine not to mention cut out the work of finding/fabricating the housing, power supply, and pre wired motors.
    After all of my reading and searching this forum and others, I am still apprehensive about wiring and getting this thing to work. I've gotten the green light to either purchase the replacement card or upgrade to the above mentioned unit. I understand I will need to use Mach 3 or something other than the Intelitek software to run the mill, but beyond that I haven't been able to find any clear instructions, write-ups, or walk throughs (which I surely thought there would be out there).
    If anyone has done this retrofit before and would be willing to lend some advice or provide a link to any resources that I haven't already been able to find I would greatly appreciate it. I would also welcome anyone weighing the benefits of just going back with Intelitek and paying the high cost of the card.
    Nick
    24223
    Re: Prolight 1000 Retrofit Newbie
    I have no knowledge of Intelitek, but Personally if this is a servo based machine and has a quality motion card, I would tend to stay with this, if they still support their product.
    Mach and steppers would be a solution, but in the end you would be close to the same budget and a lower quality system and a longer time line to get back in operation.
    Motion cards in general are closer to commercial CNC systems, and in some cases are on par.
    Al.
    Oct 2014
    9
    It is a "Light Machines" proLight 1000, which is sold and serviced by Intelitek just to clarify. It's an education based mill but apparently has a lot of potential.
    24223
    I have to retract a little, I Googled the Intelitek and found it is not much more than a Mach system, not close to the features of a commercial motion card equivalent.
    In that case, you may be better off going with Mach as it appears it has steppers also.
    Al.
    Feb 2004
    1311
    I know the founder of Light Machines but he sold the company a few years ago.
    There is actually a lot of info, google it. I found this here: http://www.cnczone.com/forums/bencht...trol-card.html
    cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Oct 2014
    9
    Smile Re: Prolight 1000 Retrofit Newbie
    Thanks for the info, I've read through that thread and a bunch of others. I guess what I was looking for is more specific to the Gecko 540 in relation to the prolight and settings within mach 3. I see that people reference in those threads like you linked to that they are running the exact set up so I've PM'd them and am awaiting a response. Just thought a new thread might throw out a wider net or a casual user may have seen something linked before that i've missed.
    I'm a high school industrial tech teacher so i'm trying to minimize the time investment here as the mill is just one of many tools/equipment to stay up on and jumping into all of these different user groups is exhausting. If I didn't care i'd just spend the $700 and buy the intelitek card and have a plug and play, but I wan to do the job right :cheers:
    Feb 2004
    1311
    Ok, that makes sense. Given that the machine is simply stepper controlled, you should have no problem interfacing a G540. The one place that might be problematic is the spindle speed control, the G540 uses a VFD output scaled from 0 to 10V for spindle speed. I am not sure how this machine controls speed but looking at the description on that page the VFD should work. What software came with the machine, is it Mach or something proprietary? If Mach, you should be able to configure it for the G540 easily. If not, you will likely need a different controller. If you go with Mach, factor that cost in. Or you could go with the open source EMC on Linux.
    The other consideration is, what voltage are the steppers running at currently? The Deepgroove1 box is setup with a 40V supply. You could simply reuse the power supply in the control box and buy a 'naked' G540. There is no real magic in the deepgroove1 box - it is basically a power supply (which may not be appropriate for your setup), the G540, an on off switch, an estop and a power cord plug. You probably have everything you need in your existing box.
    Oct 2014
    9
    I was thinking about that as well. Since my box was diagnosed as having no problems, I could probably save a little bit of money and re use some of the things that I have.
    Currently, the proprietary software is installed, but I was planning on switching over to Mach. (Assuming the Y and Z are the same?) they have 3.36v listed on them along with 2.9A
    Feb 2004
    1311
    Not sure what you mean by the Y and Z being the same?
    Oct 2014
    9
    I just realized that it looked like I was referring to the software side of things when mentioning how I assumed the Y and Z were the same. What I meant was, I removed the panel that covers the stepper motor that moves the bed in the X direction, so I could only see that motor. I'm assuming that the Y movement and Z movement motor are the same....
    Feb 2004
    1311
    The Y stepper is most likely the same. It is not uncommon to use a larger stepper on the Z since it has to lift the heavy head.
    Nov 2009
    4415
    And sometimes the Z runs a different pitch screw also. Those are all minor concerns and are adjustable in the Mach software. The steppers will be an easy interface to the G540. Skip Deepgrooves box as Michael mentions. The G540 will fit in the space of all of the old electronics. I believe you can look under Spectralight and find the same hardware.
    Btw you might want to show what town you are from. One of your neighbors might be a member and can lend a hand.
    A lazy man does it twice.
    Oct 2014
    9
    Located in Des Moines, IA.
    Took the cover off of the Z axis motors, they have the same technical markings as the others.
    Superior Electric
    Slo-Syn
    Type: m063-CS06
    Volts DC: 3.36
    Amps: 2.9
    200 Steps/Rev
    Apr 2013
    162
    Quote Originally Posted by mhackney View Post
    cheers,
    Michael
    Any chance he might still have some technical information on the servo controller used in the ProLight 2000 mill? I'd like to get it running in stock form with Linux CNC but without knowing any special commands it uses via the serial port... But that is a fortunate thing about the 2000, there's no separate box to get lost, just plug it to a PC with a single RS232 cable and it can be run off a DOS floppy or bootable USB stick.
    Sure would have been nice if the company had supported the PLM 2000 with their Windows software, but that only works with the stepper motor mills.
    Jun 2017
    4
    I am a robotics coach in MI and the high school we are based in gave us some older light machine that are no longer used... I have a CNC router, a Prolight Mill and A Prolight Lathe..
    Also planning on converting to Mach3 and i should receive a gecko g540 drive today.
    I am looking at the CNC lathe and i am trying to figure out my wiring for the DB9 connector to the g540.... the stepper motors i have a are SLO-SYN stepping motors... M063-CS06 3.36V and 2.9 amps... g540 has great instruction but i am trying to figure out the wires from the motor....
    Any help would be appreciated.
    Seb
  1. Anyone here use/have a ProLight 1000?
    By Nth in forum Benchtop Machines
    Last Post: 12-17-2013, 12:39 AM
  2. Prolight 1000 retrofit
    By cwise in forum Benchtop Machines
    Last Post: 01-31-2013, 02:30 AM
  3. proLight 1000
    By meilers@southea in forum Benchtop Machines
    Last Post: 10-14-2009, 02:09 PM
  4. proLight 1000
    By meilers@southea in forum Commercial CNC Wood Routers
    Last Post: 10-14-2009, 01:41 AM
