586,388 active members*
3,188 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Box way cnc mill build using reclaimed ways
    Apr 2010
    64
    Hello all!
    Recently decommissioned a huge grinding machine in the shop I worked for and snagged up some goodies from the machine. There were some bolt on hardened steel ways that are in fairly good condition. They are 48"x3"x1" and I have 2 of them. I am wondering a few things and searching for advice as well as examples of DIY builds if possible. I plan on building a smaller albiet heavy duty cnc mill with them and am wondering about what other people have done. I am a precision grinder and will use our cnc creep feed/reciprocate to clean up the ways and make sure they are flat and parallel to .0001" or better :-) I was thinking about using bearings on the ways in lieu of the traditional gib and surface contact set ups, but this seems like it comes with its own set of issues. Looking at our cnc grinder, which has 1-1/4" ballscrews and 2 box ways per axis, it seems as though the ball screw is the only things holding the table down vertically, which seems like it isnt enough and seems a bit strange to me. This machine however is able to creep feed off .100+ of RC60 material at 12ipm (slow but its hardenened material!!!) with zero issues. So what I am wondering is is this worth my time to use these ways and come up with a system for the machine? Thanks!
    Jun 2010
    4256
    Re: Box way cnc mill build using reclaimed ways
    You can probably put some spring-loaded roller bearings underneath somewhere to hold it down?
    But with a cast iron bed and with 4' length, I suspect the idea was that the table was not going to go anywhere unexpected. :-)
    Cheers
    Roger
  1. Fifty ways to build a relief - part seven
    By cncadmin in forum EnRoute
    Last Post: 10-30-2012, 05:40 AM
  2. Fifty ways to build a relief - Part three
    Last Post: 10-21-2012, 08:20 PM
  3. Fifty ways to build a relief - part one
    Last Post: 10-20-2012, 12:20 AM
  4. 5/6 axis build Got a ways into it. Now what
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 08-13-2009, 05:14 PM
  5. My JRGO machine build (a ways to go yet)
    By badmoonrizn in forum DIY CNC Router Table Machines
    Last Post: 05-04-2009, 12:18 AM
