Hello,
I am in the initial design phase on my first build and have been putting a good deal of though into the bearings for my gantry. I think I have a pretty good idea going here and would love some feedback. I wanted to come up with a design that I could make using a table saw, drill press and router table (the kind with a fence and a hole in the table top, not a cnc). the bearings would need to be good enough get me up running and last long enough to mill their own replacements.
Here is what I have:
Attachment 253286 Attachment 253288
It will be made from Baltic birch ply scraps I have in the shop and run on 1" steel pipe. The two lower bearing assemblies will be glued in place and the upper will have pressure applied by the nut and bolt. the middle nut is a jam nut to prevent the adjustment nut from backing out. The bottom is open to allow for the pipe to be supported from below.
The advantages I see are as follows:
1. The materials are all free shop scraps other than the skate bearings.
2. I am sure I can quickly and accurately build these with the tools I own.
Potential problems:
1. The holes for the skate bearing axles will elongate.
2. The whole assembly may bow out at the bottom (they are tall to so that the flex point is wide to handle the sheer force)
Since this is my first build I have no idea how much force is on the bearings so I am not sure if these will be problems.
