586,403 active members*
2,412 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > X axis G28 point is moving .75 after each program has completed
Results 1 to 18 of 18
    Apr 2008
    204
    Our machine has started to offset .75 the x axis every time a program finishes. Parts are to size and nothing weird going on during program. It seems to move just the x over to the right by .75 inches everytime a program finishes. Is there a macro or gcode that could have been activated unknowingly that could be causing just the x to move .75 every time to the right after a program completes?
    Here is what we have tested and know to be true:
    There are no changes from post processor output of same file from last month and today.
    Ref All home and G28 as many times as you want and it will be exactly in the same spot.
    Move all axis around machine then g28 and it will be in the exact same spot
    Calibration for steps per inch have been redone and checked. It will move exactly how much you tell it to in the calibration set up.
    If you run a program and run the same program again it will be offset .75 every program run that is processed. Only way to reset is to ref all home g28 then zero axis out.
    Parts are to size and no oblong circles.
    Y axis is not included in the offset movement.
    New drives and encoders were installed without a difference.
    Different gearhead was installed with the same outcome.
    Rack and pinion have no issues.
    15362
    Re: X axis G28 point is moving .75 after each program has completed
    davy182
    Check your settings, Go to Config Motor Home/Softlimits & see what you have set in the G28 Box, apart for this post the end part of your program this may not be correct also
    Mactec54
    Apr 2008
    204
    that part of the setting is correct and hasn't changed.
    Apr 2008
    204
    here are the gcodes that are active
    g15 g80 g17 g40 g20 g90 g94 g54 g49 g99 g64 g97
    here is a better view of what it is doing
    15362
    Quote Originally Posted by davy182 View Post
    That does not tell us anything at all, post the program, Just cut & paste it, on the Config in the above photo, is the G28 boxes blank or do you have numbers in it,
    Mactec54
    Apr 2008
    204
    ( pen )
    ( File created: Monday, October 13, 2014 - 02:15 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 48.000, Y= 96.000, Z= 0.250)
    (Toolpaths used in this file
    (pen1)
    (Tools used in this file: )
    (6 = Pen Tracing {0.05 inches})
    N100G00G20G17G90G40G49G80
    N110G70G91.1
    N120T6M06
    N130 (Tool: Pen Tracing {0.05 inches})
    N140G00G43Z0.9500H6
    N150S18000M03
    N160(Toolpath:- pen1)
    N170()
    N180G94
    N190X0.0000Y0.0000F175.0
    N200G00X0.1138Y0.1138Z0.4500
    N210G1X0.1138Y0.1138Z0.2000F30.0
    N220G1X34.3638Y0.1138Z0.2000F175.0
    N230G1X34.3638Y33.3638Z0.2000
    N240G1X0.1138Y33.3638Z0.2000
    N250G1X0.1138Y0.1138Z0.2000
    N260G00X0.1138Y0.1138Z0.4500
    N270G00X0.4888Y8.8325Z0.4500
    N280G1X0.4888Y8.8325Z0.2000F30.0
    N290G3X0.3950Y8.7388I0.0000J-0.0938F175.0
    N300G3X0.4888Y8.6450I0.0938J0.0000
    N310G3X0.5825Y8.7388I0.0000J0.0938
    N320G3X0.4888Y8.8325I-0.0937J0.0000
    N330G00X0.4888Y8.8325Z0.4500
    N340G00X0.5825Y24.7388Z0.4500
    N350G1X0.5825Y24.7388Z0.2000F30.0
    N360G3X0.4888Y24.8325I-0.0937J0.0000F175.0
    N370G3X0.3950Y24.7388I0.0000J-0.0938
    N380G3X0.4888Y24.6450I0.0938J0.0000
    N390G3X0.5825Y24.7388I0.0000J0.0938
    N400G00X0.5825Y24.7388Z0.4500
    N410G00X0.1138Y33.5783Z0.4500
    N420G1X0.1138Y33.5783Z0.2000F30.0
    N430G1X43.3638Y33.5783Z0.2000F175.0
    N440G1X43.3638Y59.8283Z0.2000
    N450G1X0.1138Y59.8283Z0.2000
    N460G1X0.1138Y33.5783Z0.2000
    N470G00X0.1138Y33.5783Z0.4500
    N480G00X5.8325Y33.9533Z0.4500
    N490G1X5.8325Y33.9533Z0.2000F30.0
    N500G3X5.7387Y34.0471I-0.0938J0.0000F175.0
    N510G3X5.6450Y33.9533I0.0000J-0.0938
    N520G3X5.7387Y33.8596I0.0938J0.0000
    N530G3X5.8325Y33.9533I0.0000J0.0938
    N540G00X5.8325Y33.9533Z0.4500
    N550G00X21.8325Y33.9533Z0.4500
    N560G1X21.8325Y33.9533Z0.2000F30.0
    N570G3X21.7388Y34.0471I-0.0938J0.0000F175.0
    N580G3X21.6450Y33.9533I0.0000J-0.0938
    N590G3X21.7388Y33.8596I0.0938J0.0000
    N600G3X21.8325Y33.9533I0.0000J0.0938
    N610G00X21.8325Y33.9533Z0.4500
    N620G00X22.6208Y45.4569Z0.4500
    N630G1X22.6208Y45.4569Z0.2000F30.0
    N640G1X20.6208Y45.4569Z0.2000F175.0
    N650G1X21.5808Y45.4569Z0.2000
    N660G1X21.5808Y46.7929Z0.2000
    N670G1X20.6208Y46.7929Z0.2000
    N680G1X22.6208Y46.7929Z0.2000
    N690G00X22.6208Y46.7929Z0.4500
    N700G00X20.8208Y47.2329Z0.4500
    N710G1X20.8208Y47.2329Z0.2000F30.0
    N720G1X20.6208Y47.6889Z0.2000F175.0
    N730G1X22.6208Y47.6889Z0.2000
    N740G00X22.6208Y47.6889Z0.4500
    N750G00X21.6450Y59.4533Z0.4500
    N760G1X21.6450Y59.4533Z0.2000F30.0
    N770G3X21.7388Y59.3596I0.0938J0.0000F175.0
    N780G3X21.8325Y59.4533I0.0000J0.0938
    N790G3X21.7388Y59.5471I-0.0938J0.0000
    N800G3X21.6450Y59.4533I0.0000J-0.0938
    N810G00X21.6450Y59.4533Z0.4500
    N820G00X5.7387Y59.3596Z0.4500
    N830G1X5.7387Y59.3596Z0.2000F30.0
    N840G3X5.8325Y59.4533I0.0000J0.0938F175.0
    N850G3X5.7387Y59.5471I-0.0938J0.0000
    N860G3X5.6450Y59.4533I0.0000J-0.0938
    N870G3X5.7387Y59.3596I0.0938J0.0000
    N880G00X5.7387Y59.3596Z0.4500
    N890G00X37.6450Y59.4533Z0.4500
    N900G1X37.6450Y59.4533Z0.2000F30.0
    N910G3X37.7388Y59.3596I0.0938J0.0000F175.0
    N920G3X37.8325Y59.4533I0.0000J0.0938
    N930G3X37.7388Y59.5471I-0.0938J0.0000
    N940G3X37.6450Y59.4533I0.0000J-0.0938
    N950G00X37.6450Y59.4533Z0.4500
    N960G00X43.9533Y53.2365Z0.4500
    N970G1X43.9533Y53.2365Z0.2000F30.0
    N980G3X44.0471Y53.3303I0.0000J0.0938F175.0
    N990G3X43.9533Y53.4240I-0.0938J0.0000
    N1000G3X43.8596Y53.3303I0.0000J-0.0938
    N1010G3X43.9533Y53.2365I0.0938J0.0000
    N1020G00X43.9533Y53.2365Z0.4500
    N1030G00X44.2096Y45.4952Z0.4500
    N1040G1X44.2096Y45.4952Z0.2000F30.0
    N1050G1X44.0096Y45.9512Z0.2000F175.0
    N1060G1X46.0096Y45.9512Z0.2000
    N1070G00X46.0096Y45.9512Z0.4500
    N1080G00X46.0096Y43.4952Z0.4500
    N1090G1X46.0096Y43.4952Z0.2000F30.0
    N1100G1X44.0096Y44.2472Z0.2000F175.0
    N1110G1X44.0096Y44.3032Z0.2000
    N1120G1X45.5056Y44.8632Z0.2000
    N1130G1X45.5056Y43.6952Z0.2000
    N1140G1X45.5056Y44.8632Z0.2000
    N1150G1X46.0096Y45.0552Z0.2000
    N1160G00X46.0096Y45.0552Z0.4500
    N1170G00X43.9533Y37.2365Z0.4500
    N1180G1X43.9533Y37.2365Z0.2000F30.0
    N1190G3X44.0471Y37.3303I0.0000J0.0938F175.0
    N1200G3X43.9533Y37.4240I-0.0938J0.0000
    N1210G3X43.8596Y37.3303I0.0000J-0.0938
    N1220G3X43.9533Y37.2365I0.0938J0.0000
    N1230G00X43.9533Y37.2365Z0.4500
    N1240G00X43.5783Y30.3303Z0.4500
    N1250G1X43.5783Y30.3303Z0.2000F30.0
    N1260G1X46.4533Y30.3303Z0.2000F175.0
    N1270G1X46.4533Y60.3303Z0.2000
    N1280G1X43.5783Y60.3303Z0.2000
    N1290G1X43.5783Y30.3303Z0.2000
    N1300G00X43.5783Y30.3303Z0.4500
    N1310G00X44.7201Y30.1138Z0.4500
    N1320G1X44.7201Y30.1138Z0.2000F30.0
    N1330G1X44.7201Y0.1138Z0.2000F175.0
    N1340G1X47.5951Y0.1138Z0.2000
    N1350G1X47.5951Y30.1138Z0.2000
    N1360G1X44.7201Y30.1138Z0.2000
    N1370G00X44.7201Y30.1138Z0.4500
    N1380G00X45.0951Y23.0200Z0.4500
    N1390G1X45.0951Y23.0200Z0.2000F30.0
    N1400G3X45.1888Y23.1138I0.0000J0.0938F175.0
    N1410G3X45.0951Y23.2075I-0.0938J0.0000
    N1420G3X45.0013Y23.1138I0.0000J-0.0938
    N1430G3X45.0951Y23.0200I0.0938J0.0000
    N1440G00X45.0951Y23.0200Z0.4500
    N1450G00X39.6413Y18.1138Z0.4500
    N1460G1X39.6413Y18.1138Z0.2000F30.0
    N1470G1X39.6413Y0.1138Z0.2000F175.0
    N1480G1X44.5163Y0.1138Z0.2000
    N1490G1X44.5163Y18.1138Z0.2000
    N1500G1X39.6413Y18.1138Z0.2000
    N1510G00X39.6413Y18.1138Z0.4500
    N1520G00X40.0163Y15.0200Z0.4500
    N1530G1X40.0163Y15.0200Z0.2000F30.0
    N1540G3X40.1101Y15.1138I0.0000J0.0938F175.0
    N1550G3X40.0163Y15.2075I-0.0938J0.0000
    N1560G3X39.9226Y15.1138I0.0000J-0.0938
    N1570G3X40.0163Y15.0200I0.0938J0.0000
    N1580G00X40.0163Y15.0200Z0.4500
    N1590G00X34.9376Y15.2075Z0.4500
    N1600G1X34.9376Y15.2075Z0.2000F30.0
    N1610G3X34.8438Y15.1138I0.0000J-0.0938F175.0
    N1620G3X34.9376Y15.0200I0.0938J0.0000
    N1630G3X35.0313Y15.1138I0.0000J0.0938
    N1640G3X34.9376Y15.2075I-0.0938J0.0000
    N1650G00X34.9376Y15.2075Z0.4500
    N1660G00X34.5626Y18.1138Z0.4500
    N1670G1X34.5626Y18.1138Z0.2000F30.0
    N1680G1X34.5626Y0.1138Z0.2000F175.0
    N1690G1X39.4376Y0.1138Z0.2000
    N1700G1X39.4376Y18.1138Z0.2000
    N1710G1X34.5626Y18.1138Z0.2000
    N1720G00X34.5626Y18.1138Z0.4500
    N1730G00X33.9888Y24.6450Z0.4500
    N1740G1X33.9888Y24.6450Z0.2000F30.0
    N1750G3X34.0825Y24.7388I0.0000J0.0938F175.0
    N1760G3X33.9888Y24.8325I-0.0938J0.0000
    N1770G3X33.8950Y24.7388I0.0000J-0.0938
    N1780G3X33.9888Y24.6450I0.0938J0.0000
    N1790G00X33.9888Y24.6450Z0.4500
    N1800G00X37.7388Y33.8596Z0.4500
    N1810G1X37.7388Y33.8596Z0.2000F30.0
    N1820G3X37.8325Y33.9533I0.0000J0.0938F175.0
    N1830G3X37.7388Y34.0471I-0.0938J0.0000
    N1840G3X37.6450Y33.9533I0.0000J-0.0938
    N1850G3X37.7388Y33.8596I0.0938J0.0000
    N1860G00X37.7388Y33.8596Z0.4500
    N1870G00X45.3514Y15.2786Z0.4500
    N1880G1X45.3514Y15.2786Z0.2000F30.0
    N1890G1X45.1514Y15.7346Z0.2000F175.0
    N1900G1X47.1514Y15.7346Z0.2000
    N1910G00X47.1514Y15.7346Z0.4500
    N1920G00X47.1514Y13.2786Z0.4500
    N1930G1X47.1514Y13.2786Z0.2000F30.0
    N1940G1X45.1514Y14.0306Z0.2000F175.0
    N1950G1X45.1514Y14.0866Z0.2000
    N1960G1X46.6474Y14.6466Z0.2000
    N1970G1X46.6474Y13.4786Z0.2000
    N1980G1X46.6474Y14.6466Z0.2000
    N1990G1X47.1514Y14.8386Z0.2000
    N2000G00X47.1514Y14.8386Z0.4500
    N2010G00X41.5428Y9.9607Z0.4500
    N2020G1X41.5428Y9.9607Z0.2000F30.0
    N2030G1X41.3428Y10.4167Z0.2000F175.0
    N2040G1X43.3428Y10.4167Z0.2000
    N2050G00X43.3428Y10.4167Z0.4500
    N2060G00X43.3428Y8.1847Z0.4500
    N2070G1X43.3428Y8.1847Z0.2000F30.0
    N2080G1X41.3428Y8.1847Z0.2000F175.0
    N2090G1X42.3028Y8.1847Z0.2000
    N2100G1X42.3028Y9.5208Z0.2000
    N2110G1X41.3428Y9.5208Z0.2000
    N2120G1X43.3428Y9.5208Z0.2000
    N2130G00X43.3428Y9.5208Z0.4500
    N2140G00X45.0013Y7.1137Z0.4500
    N2150G1X45.0013Y7.1137Z0.2000F30.0
    N2160G3X45.0951Y7.0200I0.0938J0.0000F175.0
    N2170G3X45.1888Y7.1137I0.0000J0.0938
    N2180G3X45.0951Y7.2075I-0.0938J0.0000
    N2190G3X45.0013Y7.1137I0.0000J-0.0938
    N2200G00X45.0013Y7.1137Z0.4500
    N2210G00X40.0163Y3.2075Z0.4500
    N2220G1X40.0163Y3.2075Z0.2000F30.0
    N2230G3X39.9226Y3.1137I0.0000J-0.0938F175.0
    N2240G3X40.0163Y3.0200I0.0938J0.0000
    N2250G3X40.1101Y3.1137I0.0000J0.0938
    N2260G3X40.0163Y3.2075I-0.0938J0.0000
    N2270G00X40.0163Y3.2075Z0.4500
    N2280G00X34.9376Y3.2075Z0.4500
    N2290G1X34.9376Y3.2075Z0.2000F30.0
    N2300G3X34.8438Y3.1137I0.0000J-0.0938F175.0
    N2310G3X34.9376Y3.0200I0.0938J0.0000
    N2320G3X35.0313Y3.1137I0.0000J0.0938
    N2330G3X34.9376Y3.2075I-0.0938J0.0000
    N2340G00X34.9376Y3.2075Z0.4500
    N2350G00X33.8950Y8.7388Z0.4500
    N2360G1X33.8950Y8.7388Z0.2000F30.0
    N2370G3X33.9888Y8.6450I0.0938J0.0000F175.0
    N2380G3X34.0825Y8.7388I0.0000J0.0938
    N2390G3X33.9888Y8.8325I-0.0938J0.0000
    N2400G3X33.8950Y8.7388I0.0000J-0.0938
    N2410G00X33.8950Y8.7388Z0.4500
    N2420G00X36.4640Y9.9607Z0.4500
    N2430G1X36.4640Y9.9607Z0.2000F30.0
    N2440G1X36.2640Y10.4167Z0.2000F175.0
    N2450G1X38.2640Y10.4167Z0.2000
    N2460G00X38.2640Y10.4167Z0.4500
    N2470G00X38.2640Y8.1847Z0.4500
    N2480G1X38.2640Y8.1847Z0.2000F30.0
    N2490G1X36.2640Y8.1847Z0.2000F175.0
    N2500G1X37.2240Y8.1847Z0.2000
    N2510G1X37.2240Y9.5208Z0.2000
    N2520G1X36.2640Y9.5208Z0.2000
    N2530G1X38.2640Y9.5208Z0.2000
    N2540G00X38.2640Y9.5208Z0.4500
    N2550G00X17.9771Y17.1445Z0.4500
    N2560G1X17.9771Y17.1445Z0.2000F30.0
    N2570G1X18.4331Y17.3445Z0.2000F175.0
    N2580G1X18.4331Y15.3445Z0.2000
    N2590G00X18.4331Y15.3445Z0.4500
    N2600G00X15.9771Y15.3445Z0.4500
    N2610G1X15.9771Y15.3445Z0.2000F30.0
    N2620G1X16.7291Y17.3445Z0.2000F175.0
    N2630G1X16.7851Y17.3445Z0.2000
    N2640G1X17.3451Y15.8485Z0.2000
    N2650G1X16.1771Y15.8485Z0.2000
    N2660G1X17.3451Y15.8485Z0.2000
    N2670G1X17.5371Y15.3445Z0.2000
    N2680G00X17.5371Y15.3445Z0.4500
    N2690G00Z0.9500
    N2700G00X0.0000Y0.0000
    N2710M09
    N2720M30
    Apr 2008
    204
    here is the screen shot. A new computer was tried with fresh install of mach3 and nothing different.
    15362
    Your program is in incremental G91.1, you want to do you program using absolute G90, you also don't need a G94 & the G70 in the program
    You also don't have a G54 for your work offset, so the control does not know were to return to work Zero
    By using the G28 to reset your machine it will move to what your settings are, from machine Home & the numbers you have set in the G28 settings
    Mactec54
    Apr 2008
    204
    bad connector
    Sep 2014
    18
    I would at least try mactech54 recommendation, sometime the cad system you my be using does not include these codes in the parameters, but can be alterd, just take a better look at the manuals.
    No, it's not.
    N100G00G20G17G90G40G49G80 < This puts the machine in Absolute mode
    N110G70G91.1 < This puts the machine in Incremental IJ mode
    The program is in G90, and stays in G90 throughout.
    We've had this discussion before. This is standard practice for Mach3, and is correct.
    I don't see anything in the code to cause it to do what you're saying. It could be something in your M6 macro, or I'd guess it's mechanical and it's loosing steps somewhere.
    At the end of the program, does the pen finish at the corner where it started?
    If you set X and Y to zero before it starts, does it start there, or move .75 before it starts drawing?
    15362
    No, it's not.
    Nobody said there was anything in the code that would cause it to do what it was doing, his Program is in Incremental If you have a G91.1 after a G90 then your Program will be executed in Incremental
    It was what he did to move his machine that made it move to where it was, He used a G28 to move the machine after the program had finished & this would move his machine to were ever he has the setting set in relation to the Machine Zero or work Zero, depending how he had his work set up
    The top line of code is a safety line which cancels or activates those codes, In this case there is a G90 ( absolute ) which is only active until is see's the G91.1 ( Incremental )
    N110G70G91.1
    N120T6M06
    There is nowhere else in the Program that there is a G90 after this G91.1,so his Program would be run in Incremental
    Mactec54
    No, it won't. You're 100% wrong.
    If you'd run the program in Mach3, you'd see that it stays in G90 (Absolute) through the entire program. It never changes to incremental, because G91.1 IS NOT INCREMENTAL!!
    Stop trying to tell people it is, when it's not.
    15362
    So the Mach3 instruction manual is wrong then
    G90 & G91 are a Preparatory Function Plus they are Modal
    Mactec54
    No, G91.1 is incremental IJ mode, and has nothing to do with G90, which puts Mach3 in absolute DISTANCE mode.
    His code runs in absolute distance mode throughout (G90).
    15362
    You are saying the G91.1 serves no purpose,other than to do the I & J in incremental,
    So if you have your control Configured correctly, to normal industry standard, as it should be, the G91.1 would be redundant, as it serves no purpose, Most controls Default to Incremental for I & J just the same as you can configure it in Mach3
    Mactec54
    What I'm saying is that you're giving out incorrect information:
    You're now trying to change the subject.
    Vectric adds a G91.1 to their code so they don't get hundreds of support calls because their IJ mode is set wrong. I guess they should send them to you so you can tell them their machine is configured incorrectly, which has nothing to do with the OP's problem.
    Conversation over.
    Apr 2008
    204
    ok here is the rundown and would be a good idea to write down in the books for a problem check, as it is out of my realm of expertise to explain:
    The x motor had a frayed/most strands broken on the ground for the motor. It was on the cnc side of the wiring and not the motor side of the connector, hence when a different motor with gear-head was swapped it had the same issue. Once the ground was repaired poof problem solved. If anyone can explain how the motor only moved right and exactly .75 inches because of the ground issue I would like to know.
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. moving focus point
    By arnoldino in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-04-2013, 09:30 PM
  3. Replies: 9
    Last Post: 12-24-2011, 03:36 PM
  4. V24, moving start point
    By tome9999 in forum BobCad-Cam
    Last Post: 01-20-2011, 02:59 AM
  5. Replies: 2
    Last Post: 02-07-2009, 12:59 AM
