586,149 active members*
3,507 visitors online*
Results 1 to 11 of 11
    Aug 2006
    5
    Question How to trig out I and J ?
    Hello everyone, I have been working as a machinist (operator) for about 20
    years. I have now started work in a small shop where we do a lot of our
    programming at the machine. (Fadal) What I need is some good examples
    of how to figure out I and J on a outside and inside radius using trig. Why
    and when it changes to I- and J- Any good books or online resources
    would be great.
    Mar 2004
    1543
    Are you asking how to solve for the circle center when you don't know it? The math on this is a bit involved. If you have autocad, or another CAD you can input three points on the circle and it will draw the circle and determine the center.
    If you're asking how to get I and J when you have the start point, end point and radius, 9 times out of 10 one of the circle points is exactly on the X or Y axis from the radius. Then you can just subtract. I don't know the trig formula for cases when neither end point lines up, but its not too bad. Again. autocad or another CAD makes this a piece of cake to find the center.
    I and J have negative values any time the X or Y distance to center is in the negative direction.
    Karl
    Oct 2003
    263
    Try this link for an explanation with illustrated examples. Shows up best in Internet Explorer.
    http://technology.calumet.purdue.edu...iles/frame.htm
    Software For Metalworking
    http://closetolerancesoftware.com
    Sep 2006
    7
    Why would you want to use I, J, just use R0+
    G1 F5.
    X0Y0
    G2X.5Y.5R0+.5
    THIS WILL CUT A .5 R ,ALL YOU NEED IS A START POINT X0Y0 AND END POINT X.5Y.5 WITH A RAD CALLOUT R0+.5
    FADAL WILL LET YOU CALL END POINT AND RAD IF YOU USE R0+" " FOR THE RAD
    Jun 2005
    95
    vmc4020,
    Here are a few links. I use these textbooks with my students. Both will contain what you are looking for and are a handy shop reference.
    http://www.cncci.com/ - Machining Center Programming, Setup, and Operation Self Study Manual
    THIRD EDITION
    A Guide To Mastering The Use Of CNC Machining Centers
    http://www.industrialpress.com/en/Bo...5/Default.aspx
    Feb 2005
    78
    Have a go at this mate
    John
    Attached Files Attached Files
    Jun 2003
    205
    Trig Software Tool
    If you want something that will do it automatically ... without an overpriced CAD package ... try our Trig Kalculator software.
    Info at www.KentechInc.com
    Kalculator will calculate line-to-line intersecting points as well as line-arc-line points and arc centers from fill-in-the-blank forms ... then plots the results on the screen. It also does the standard right and obtuse triangle calculations ... price is $95.
    Aug 2006
    5
    Smile
    Thanks to everyone for the help and advise. It is not hard when programming a 90 degree radius. Its calculating partial acs that was giving me problems.
    All I have is my calculator and my trig book. I need to study up on my geometry also. The example John sent is what I am looking for. It looks more like a lathe job (I and K) but the the same math should apply using I and J
    on a mill. (Center of the arc to the center of the cutter.)
    Oct 2005
    251
    Try drawing arc on graph paper. Simple sketch will do. Mark center point and then draw right triangles from center of arc to the beggining and end points. Once you have the triangles on the paper you can select the lines which represent the I,J,K values you wnat to find. Use trig to solve for the sides of the triangles.
    Sep 2006
    23
    how do i view oldjohn's file? i see the words but is there a diagram too? i would like to learn how to program a radius that blends into an angle on a haas sl40. i run a haas sl40 lathe and a mazak quick turn 30 with a t plus control. we would like to be able to run the same type of parts on these machines, but i am unable to program things like this on the haas. we dont use any programming software.
    Feb 2005
    78
    vmc4020
    What you need is this tool. Make a copy and get a transparency and laminate it. Place it on top of your drawing as per instructions.
    Good luck
    John
    [IMG][/IMG]
