587,006 active members*
3,188 visitors online*
Results 1 to 2 of 2
    Apr 2014
    7
    How to get my 5v relay to turn on and on
    Hello
    It has been a while since I have posted
    My setup is working very well, thanks to everyone for their help
    I am trying to upgrade a little
    So, my setup is using MACH3 and a TB6560-V2.5 control board. It is a cheap 3 axis board from China, but it works for me
    On the board are connections for 4 limit switches, and beside these are 2 connections for 5VDC pos & neg relay. I thought these might control on/off for a spindle, but no luck. I don't know if I have a settling wrong or a wrong code.
    I have set MACH3 as follows: Output Signal, Enable 1, port 1, pin 1, active low checked
    Output 1, port 1 pin 14, active low not checked
    Spindle Setup, Relay enabled, both Outputs # 1
    In my software I have tried M3 & M5
    I only want to turn this 5 v relay on & off with the software.
    Any suggestions would be great
    Thanks & Cheers
    Steve
    Jan 2013
    119
    Re: How to get my 5v relay to turn on and on
    SKLCNC55
    Go into Configuration / Ports and pins /Spindle setup
    Make sure that you don't have the relays disabled.
    Happy holidays
    Mike
  1. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  2. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  3. Newbie-> Using G Code to turn a relay on
    By Delanoman in forum G-Code Programing
    Last Post: 08-30-2009, 05:33 AM
  4. relay to turn plasma on needed with bob campbell
    By Wolfesmetalfab in forum CNC Machine Related Electronics
    Last Post: 01-04-2009, 09:26 PM
