587,012 active members*
3,442 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How to read magnetic incremental encoder specs - yc-52010
Results 1 to 5 of 5
    Feb 2008
    3
    Hello All,
    I am trying to build a Maslow CNC, so I purchased a pair of motors on ebay , note that I am quite new to this.
    However I am unable to understand specification table as presented on the item page..
    I can not figure out the CPR, PPR or resolution of the encoder.
    Unfortunately the seller keeps referring me to the data on the page.
    Hoping someone can help, see pics of data below:
    http://www.cnczone.com/forums/attach...d=383884&stc=1
    http://www.cnczone.com/forums/attach...d=383886&stc=1
    http://www.cnczone.com/forums/attach...d=383888&stc=1
    Link to motor : Motor
    Best Regards,
    Attached Thumbnails Attached Thumbnails encoder1.jpeg   encoder2.jpeg   encoder3.jpg
    Dec 2013
    5714
    Re: How to read magnetic incremental encoder specs - yc-52010
    If I'm translating that table correctly, it looks like a 12mm diameter motor has a 3 line encoder, and the 42 mm diameter motor has a 18 line encoder. Normally the counter will read both the rising and falling square wave edges, so the pulses per revolution is 4 x the line count, so 12 to 72 PPR depending on the motor size.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    3
    Hello Mr. Dawson,
    Thanks, that makes sense, my motor is 37mm as per diagram, therefore am I using the value for 36mm in the table i.e 16 line count ?
    So PPR = 16 x 4 = 64 ?
    Just for some extra information, I tracked down that encoder to this site : https://www.yoycart.com/Product/42299022187/
    The info simply did not help(me).
    Is it usually to specify resolution according to motor diameter?
    Thanks very much for taking the time to answer my question.
    Best Regards.
    Dec 2013
    5714
    You're welcome !
    I have never seen an encoder spec'd by the motor diameter. But apparently they install whichever encoder that physically fits on the motor, and can only get the magnetic poles just so close together. I have never seen a digital encoder like this, normally the output of this type of system is dual analog sine wave which is then converted to a digital output. They just skipped that step.
    My best guess is that you could use the 36mm table, but who knows. You should be able to measure the output pulses with a voltmeter and check the actual line count. Connect power to the encoder, connect the voltmeter to the output, and rotate the motor shaft with your fingers. Count the number of transitions in one motor rotation.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    3
    Sounds good,
    I will try to measure the pulses as you described. The price of the unit blinded me to the lack of documentation
    Over the weekend I will give it a try and I will tell you how it went.
    Regards.
  1. Replies: 0
    Last Post: 02-21-2015, 02:03 PM
  2. Incremental Encoder
    By MarunovV in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-27-2013, 05:05 AM
  3. DIY Incremental encoder
    By bunalmis in forum Hobby Discussion
    Last Post: 03-30-2008, 12:24 AM
  4. Incremental encoder
    By mihan in forum CNC Machine Related Electronics
    Last Post: 09-10-2005, 10:21 PM
  5. Incremental encoder
    By mihan in forum Open Source CNC Machine Designs
    Last Post: 09-09-2005, 10:09 PM
