587,006 active members*
3,198 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Kollmorgen S Series A/C Servo drives: How do I connect them for Mach 3 Step/Direction
Page 4 of 4 234
Results 61 to 76 of 76
  1. #61
    Sep 2010
    1765
    Re: Kollmorgen S Series A/C Servo drives: How do I connect them for Mach 3 Step/Direc
    should be easy to diagnose this.... see screen shot of how it should be set up. did you pick "remote enc input? What screenshot? I see no attachments.
    Is motor holding position or just free wheeling? Not since I re-did the wires. But first try with only two wires connected the axis was 'creeping' in one direction with no control.
    sorry, got a customer call and forgot to attach. will try to remember and do after Jag show......
    if drifting, that guarantees you were NOT in mode 4 only velocity mode.
  2. #62
    May 2013
    5
    Dear, can you put wiring diagram here. Best regards.
    [QQUOTE=jxdxwx;1690056]
    I will look over the drive settings when I get home and let you know. Yes my MotionLink computer is connected to the internet. It is currently the same computer that I am running Mach3 on also. Should be able to minimize screens if you need both to be running.
    How and when do you want to connect thru internet ?
    John
    [/QUOTE]
  3. #63
    Aug 2005
    114
    Diagrams attached.
    Let me know if it helps.
  4. #64
    Aug 2005
    114
    You sent me another PM but my mailbox is full.
    I didn't get it. so resend or post here.
  5. #65
    Sep 2010
    1765
    Quote Originally Posted by shejta View Post
    John
    [/QUOTE]
    TEAMVIEWER PROGRAM TO CONNECT. You need to have it all turned on and running for me. I would hook in and help you for 15-20 minutes. I have hamfest tomorrow morning so maybe tomorrow (Sat) 2:15-2:30pm EST? or maybe sometime on Sun? Since it is free help, I cannot do early next week as I have commitments.
  6. #66
    Aug 2005
    114
    Mike, thank you but I am actually currently running fine.
    The msg was an old one that another user cut and pasted and referred to.
    I am helping him with my wiring schematics.
    May take you up on some fine tuning at somepoint in the future, but for now all is well.
    THANKS!!!
    John
  7. #67
    Sep 2010
    1765
    thanks!
  8. #68
    May 2013
    5
    Dear, Thank you so much for help, In next couple minutes I will post images of drive and screenshots from program setup. Just to note, on display is currently E03. ( with dot). What that mean? Best regards
  9. #69
    May 2013
    5
    Attachment 330598Attachment 330600Attachment 330602Attachment 330604Attachment 330606Attachment 330608Attachment 330610Attachment 330612Attachment 330614Attachment 330616Attachment 330618
  10. #70
    May 2013
    5
    Also, I want ot connect this board: Sorotec - Interface Advanced PRO and manual is located on this link http://www.sorotec.de/webshop/Bedien...ut8-Manual.pdf
  11. #71
    Sep 2010
    1765
    apples and oranges? there is no such display E03 on a Servostar SE or SR series drive. There IS that display on an S600 drive and it would mean it is a 3amp drive and E for ENABLED. Totalaly DIFFERENT animal.
    I cannot handle discussing this on here; I MUST use email as I cannot sit in front of this computer all the time. my email is [email protected]
  12. #72
    Sep 2010
    1765
    HA! so I just saw ur pictures. you are talking about a TOTALLY DIFFERENT DRIVE than everyone else previously.
    I have no idea what YOUR problem is.
    I wanted to leave office 2 hours ago and have been stuck with a couple customers needing help; email me if you would like me to respond maybe tonight. It is WAY past Miller time here!
  13. #73
    Mar 2021
    I'm trying to do the same thing as the OP in this thread.
    I have a S310 hw rev 3.01, firmware 3.88 and was able to connect to the DBL4N00750 - 03M - 000 - S40 servo using DriveGUI and jog the motor with motion service.
    I need to control the S310 drive with step/direction input as described on pg 88 of the manual. The problem I'm facing is that every time I try to enter the setup wizard, the DriveGUI program crashes. I'm running Windows10.
    Is there a known issue and/or workaround with using the DRIVEGUI setup wizard on older drive firmware?
    Alternatively, if anyone has a suggestion for a better drive to use than an s310 that can be had on eBAY for under $500, I would appreciate suggestions. I prefer to run on single phase 220V.
  14. #74
    May 2013
    5
    Hello
    Driver.exe (program for kolmorgen setup) doesn’t work very well on windows 10. Try to use windows compatibility options and set to XP compatibility or Windows 7. I am implemented several machines using those drives and step - dir input. Mostly used CSMIO ip-m or S because they use differential output. A lot of help I got from Mike Kilroy. He is genius.
    QUOTE=MD21921;2440718]I'm trying to do the same thing as the OP in this thread.
    Alternatively, if anyone has a suggestion for a better drive to use than an s310 that can be had on eBAY for under $500, I would appreciate suggestions. I prefer to run on single phase 220V.[/QUOTE]
  15. #75
    Mar 2021
    Thanks for the windows version suggestion! I was able to get it configured using a windows7 PC.
  16. #76
    Sep 2010
    1765
    Quote Originally Posted by MD21921 View Post
    Thanks shejta for helping him!
Page 4 of 4 234
  1. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  2. AC servo Step Direction drive
    By professor in forum Servo Motors / Drives
    Last Post: 11-10-2007, 05:07 PM
  3. Replies: 2
    Last Post: 07-28-2007, 11:17 AM
  4. step and direction control for opto22 servo drive
    By drewgarth in forum Servo Motors / Drives
    Last Post: 05-21-2006, 07:31 PM
  5. Servo motor, step/dir driver and Mach.
    By Darc in forum Mach Mill
    Last Post: 04-11-2006, 06:23 AM
