586,728 active members*
3,123 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > CAM software just for generate engraving lines on the surface
Results 1 to 2 of 2
    Aug 2014
    18
    Guys, I'm almost building my CNC. I came up with a question. Say I have a complex geometry that needs to have some drawings on top. Assuming I have the slt drawing of this figure.
    This geometry may be flat surfaces, curved, etc. .. If I wanted to just write or draw little lines on the surface .. the CAM software can do this?
    In other words, I have as input the complex geometry and the lines need to be drawn on the surface (if I can do engraving on the surface where I need to pass the drill).
    In the end, cnc machine would just go the route of the line on the surface (being any type of surface: regular, irregular, etc).
    I saw the videos on youtube, usually the part to be machined is a rectangle or a general surface. In the CAM software I can insert my custom initial geometry?
    Look for example this computer mouse, I would insert the STL model of the mouse as initial geometry (which will be machined) and the STL model of the mouse --->already machined<---. Finall, the CAM software would generate just the drawing on the picture (the skull **)
    Can CAM softwares do it (just engraving on the general surface)?
    Thank's
    Aug 2014
    18
    Re: CAM software just for generate engraving lines on the surface
    if there are softwares.... can you tell me some softwares?
  1. Replies: 1
    Last Post: 12-27-2013, 09:31 PM
  2. Replies: 2
    Last Post: 08-26-2013, 07:37 AM
  3. Straight Lines on Curved Surface.
    By Navatek in forum CNC Tooling
    Last Post: 08-15-2011, 11:45 PM
  4. Replies: 2
    Last Post: 09-12-2009, 06:44 PM
  5. How to generate g-code to mill flat surface
    By pminmo in forum G-Code Programing
    Last Post: 09-10-2006, 06:33 PM
