586,512 active members*
3,548 visitors online*
    Sep 2013
    17
    Adding additional functions to KFLOP pause
    is there a way of adding additional functions, such as spindle stop to the pause function? something like the user buttons but linked to the pause? is this possible?
    thanks,
    Rich.
    May 2006
    4047
    Re: Adding additional functions to KFLOP pause
    Hi Rich,
    We will look into this. Other Users have requested this. As you describe we were thinking to add the ability for an "Action" (same options as for MCodes and User Buttons) that would be performed after the Halt. So then something like a Spindle off and move to Safe Z on a halt. One concern might be how safe it is to always perform a Z Move in all Halt Conditions.
    We would probably add the same capability for before Cycle Start, after abort, and at End of Job.
    Any further thoughts?
    No promises on when this would be available.
    Regards
    TK
    http://dynomotion.com
    Sep 2013
    17
    Tom,
    we have a router at work which stops the cutting head and lifts it off the work piece when paused, on resume it starts the cutter, waits a short time for it to reach the set speed and then drops down to resume the cut. it would be nice to be able to implement this on my own machine (also a 3-axis router) which I have the kflop on.
    Cheers,
    Rich.
  1. Adding an additional axis on a build
    By SteveSy in forum Open Source CNC Machine Designs
    Last Post: 09-16-2009, 11:55 AM
  2. Adding Additional Plugins to Mach3
    By GBBR2233 in forum Tormach Personal CNC Mill
    Last Post: 02-11-2008, 03:07 PM
  3. hardeware pause pause detected?????
    By Conquest1224 in forum Commercial CNC Wood Routers
    Last Post: 05-08-2007, 04:06 AM
  4. Mach & Additional IOs
    By aus-newb in forum Mach Lathe
    Last Post: 12-18-2006, 05:07 PM
  5. Additional forum
    By HuFlungDung in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2003, 02:52 AM
