587,008 active members*
3,670 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Sabre 500 spindle fan mysteriously packed with grease?
Results 1 to 6 of 6
    Aug 2009
    223
    I have a Sabre 500 which I recently bought, and it's FILTHY. I'm cleaning it up during my retrofit, and I came across something odd.
    Attachment 253050
    The red cap on top of the spindle motor contains a cooling fan. The top of that housing was covered in cakey grease, so much so that the airflow through it must be restricted.
    I pulled the fan housing to clean it, and discovered that it is PACKED with grease inside. Not just greasy, but like an inch thick layer around the inside of the housing, with the fan blade tips dragging through the grease. It seems like clean, fresh grease, so it must be there intentionally. There doesn't seem to be a zerk on it anywhere, so it seems like it was packed with clean black grease, then the fan was installed.
    Attachment 253052
    This is after taking it apart and starting to clean it up. I've literally taken handfuls of grease out of there at this point.
    The fan itself is a pretty normal pancake style fan, although it's 3 phase:
    Attachment 253054
    I really can't imagine why that grease would be there, what purpose it serves. The top of the spindle motor is a sealed case, so there's no need for grease for it. The only thing I could possibly guess is to catch chips or dust or something?
    I found another similar fan on ebay, and it's grease-free:
    Attachment 253056
    Ian
    Feb 2009
    6028
    Re: Sabre 500 spindle fan mysteriously packed with grease?
    Looks like 1/2 dried coolant. Pretty normal really on non well maintained machines. Seen it more than once.
    Dec 2003
    24223
    Sounds like some misguided maintenance person to me?
    Fans are usually kept as clear as possible to be effective.
    Al.
    Albert E.
    Aug 2009
    223
    I washed the housing out real well and re-assembled. It seems to run quietly and happily without the grease, so that's how I'll leave it. Best explanation I've heard yet is that the fan is sucking grease and crud up from below and slinging it centrifugally to the outside of that housing, and that's just decades of buildup.
    Ian
    Jan 2005
    15362
    tmbg
    As the other poster said, it is coolant, this is very normal with machining centers, cutting fluid/coolant ( Mist ) some are worse than others, most machines never get cleaned in this area until something fails, just think the operator was breathing that same gunk in as well
    To help prevent this Coolant Mist, they have Coolant Mist Collectors mounted above the machines & around the shop to help clear/clean the air
    Mactec54
    Dec 2006
    585
    The fan on this Fanuc motor pulls air from the bottom of the motor and sends it out the top of the motor. Was the sheet metal guard that goes around this area installed on the machine ??? Did you look at the baffles in the motor and the bottom of the motor?? If it is clean, then someone got crazy with a grease gun.
    Mike cncmachineservices (dot) com
  1. Z axis mysteriously gets more and more inaccurate
    By acannell in forum Dyna Mechtronics
    Last Post: 05-07-2014, 06:31 AM
  2. TL spindle bearing grease
    By garylb in forum Haas Lathes
    Last Post: 11-12-2012, 08:53 AM
  3. I Need Some Spindle Bearing Grease!
    By bjorn toulouse in forum Want To Buy...Need help!
    Last Post: 02-18-2011, 10:50 AM
  4. Shop Sabre Grease
    By setguy in forum Shopsabre
    Last Post: 09-11-2009, 08:53 PM
  5. Spindle Grease ?
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2005, 10:25 PM
