586,493 active members*
1,963 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Strange Rigid tapping Problem . Please help
Results 1 to 20 of 32
    Jan 2013
    49
    Hi everyone
    I Need an urgent help with my OM control in rigid tapping Mode (G84) .
    the problem is that z axis comes down to the position (R point) and spindle orients itself but it hangs there with no alarm .
    the spindle rotation cw/ccw lights on the panel sequentially turn on and off .but no rotation unless i stimulate the spindle head manually .
    if i do that it starts rigid tapping according to my program .
    My program is:
    G90 G17 G54
    S200 M3
    G00 G43 X0.0 Y0.0 Z100.0 H1
    M29 S500 F200
    G84 Z0.0 R150.0 P300 F200
    G80 P0
    M30
    Any help would be really appreciated
    [email protected]
    Regards
    Dec 2012
    395
    Re: Strange Rigid tapping Problem . Please help
    This is an example from my YCM with Fanuc 21i-M.
    Check your manual at pages 165 and 166 for rigid tapping, ( Fanuc 0M - Operators Manual - GFZ-61404)
    Some codes are not functional for your control, line N020 and N025 maybe.
    O400 ( RIGID TAPPING M8X1.25)
    N010 G54 G17 G40 G80 G94
    N015 G00 G91 G28 Z0
    N020 G90 G49
    N025 G10 L91 R4.
    N030 T01
    N035 M06
    N040 G95 ( MM/REV )
    N045 S650 M03
    N050 /M08
    N055
    N060 G00 G90 G43 X50. Y0 Z20. H01
    N065 M29 S650
    N070 G84 R5. Z-20. F1.25
    N075 X0 Y50.
    N080 X-50. Y0
    N085 X0 Y-50.
    N090 G80
    N095 G94 ( MM/MIN )
    N100 G00 G90 Z100. M09
    N105 G28 G80 G91 Y0 Z0 M05
    N110 M30
    Heavy_Metal
    Jun 2008
    you will have problems if you start spindle rotation at 200 rpm and tell it to calculate rigid tapping at 500 rpm
    Dec 2008
    3110
    Quote Originally Posted by Behnod View Post
    G90 G17 G54
    S200 M3
    M29 S500 F200
    G80 P0
    M30
    Re-hash of your code
    Code:
    G54
    G0 G17 G40 G90 G94 ( better safety line )
    S200 M3
    G00 X0.0 Y0.0
    G43 Z100.0 H1
    M29 S500
    G95  (feed per rev, )
    G98 G84 Z0.0 R150.0 F0.4 (G98/G99 required for return to retract (or initial) Zplane, check manual)
    G80 G94 (cancel cycle, feed per min)
    M30
    used G95 so that F can be the thread pitch, & will not need altering if the RPM is changed
    .........NOTE..... G94 is required to switch back to normal machine that won't seem like everything is in rapid
    XYZ first move broken up to eliminate 3 axis move (crash fodder)
    F200 may need decimal for mm instead of microns
    P300 dwell not required, ( may cause program stoppage )
    P0 deleted, not needed with G80 ( may cause program stoppage )
    Jan 2013
    49
    Dear Superman
    I tried your recommended program , put decimal in feed and deleted P300 and P0 , but again it didn't do tapping until i rotate the spindle by hand .
    Jan 2013
    49
    Thanks william
    i changed the program to :
    G90 G17 G54
    S500 M3
    M29 S500 F200
    G80 P0
    M30
    But it hangs again .
    i think there is a problem with a parameter or hardware . but the case is that there is no problem with machine . it does everything well . the only problem i face is with Rigid tapping .
    Jan 2013
    49
    dear Heavy_Metal
    i checked the manual but couldn't find anything special . the saple program is:
    M29 S**
    G84 Z**R**Q**F**
    G80
    Dec 2012
    395
    Did you check my program?
    Why is your R150. value bigger than the Z100. in the 3rd line?
    G90 G17 G54
    S200 M3
    M29 S500 F200
    G80 P0
    M30
    Heavy_Metal
    Jan 2013
    49
    Thank guys for your kind and quick replies .
    we used to use this program for rigid tapping before . but an electrical defect caused parameters lost . we restored the parameters and now everything work well except rigid tapping.
    i think the program needs a signal or waiting for a command to do rigid tapping .
    the parameters related for tapping on OM .
    19#4 =1 signal 135 or 123
    256=29 M code
    911#2=0 rigid tapping
    do you think there may be a problem with a parameter or hardware ?
    regards
    Jan 2013
    49
    Sorry Heavy_Metal it's just typing mistake
    the first Z is Z200.0
    Dec 2012
    395
    I attached the Fanuc pdf Parameter Manual GFZ-61410.
    Search for "rigid" and you'll see that there are a lot of parameters for rigid tapping.
    Maybe you have to change some other parameters.
    Heavy_Metal
    Attached Thumbnails Attached Thumbnails Fanuc-0M-Operator_Manual-GFZ-61404-E.pdf   Fanuc-0M-Parameter-Manual-GFZ-61410-E.pdf
    Apr 2012
    40
    Is there really a need for the S200 M3 before the tap cycle?
    When we do rigid tapping the output is as follows, with just the M29 and spindle speed wanted? Maybe the two spindle commands are hanging it up.
    G0 G90 G54 X3. Y1.5
    G43 Z2. H19 M8
    M29 S1300
    G84 G98 Z-.75 R.1 F100.
    Y.5
    X12.25
    Y1.5
    X21.5
    Y.5
    G80
    G0 Z2.
    M5
    Jan 2013
    49
    Thanks diamond
    i have tried both with S200 M3 command and without S200 M3 .
    there is no movement in Z axis unless giving the spindle a hand .
    it comes to R level or initial level ( depending on G98 or G99) and after orienting the spindle hangs there with a small movement in spindle ( like M19 command) , not executing rigid tapping .
    after stimulating the spindle it does rigid tapping accordingly .
    Apr 2012
    79
    Hi
    Have you tried putting m19 before the cycle. I had to do this on an O-Mate control I used to run.
    EG
    M19
    M29 S500
    G84 etc
    Hope this helps
    Jan 2013
    49
    Sorry for delay .
    Thanks my friends for your kind replies and suggestions .
    Up to now I tried so many ways including your suggestions to solve rigid tapping problem in my OM but i couldn't .
    Do you think there may be a hint that i have missed ?
    Regards
    Dec 2012
    395
    Did you check parameter 076#3 = 1 ( FANUC 0M )
    0076#3 - G84RGD - G84 and G74 are not handled as G codes for rigid tapping/are handled as G codes for rigid tapping.
    Pages 18 and 19, Fanuc 0M - Parameter Manual GFZ-61410
    I send you the pdf files earlier.
    Did you try the "normal" G84 tapping without M29 ?
    Try it in a free Z-level.
    Heavy_Metal.
    Sep 2012
    182
    I have the exact same issue with my fanuc tape drill. it stops and hunts on rigid tapping. unfortunately I have not found a solution.
    Jan 2013
    49
    Hi.
    Heavy_Metal.
    Thank you for the files.
    I have tried both 76#3=1 and =0 with and without M29 but it's not working .
    Jun 2013
    1041
    I notice that in all the g-code programs you posted the G84 is followed by Z0.0. Try making that Z move a negative value like Z-10.0.
    Ben
    Jan 2013
    49
    Dear Ben
    i changed all the zs to minus values but no result.
  1. Rigid Tapping Problem
    By EricMFG in forum Kitamura
    Last Post: 09-15-2012, 03:07 AM
  2. Rigid tapping problem on VF-2
    By Frank_S in forum Haas Mills
    Last Post: 07-06-2012, 06:45 PM
  3. Rigid Tapping OM-D problem
    By yoshi900 in forum Fanuc
    Last Post: 03-04-2011, 03:21 PM
  4. vmc intermittant rigid tapping problem
    By ethanbrush in forum Fadal
    Last Post: 09-29-2010, 03:46 PM
  5. Rigid tapping problem
    By GITRDUN in forum Haas Mills
    Last Post: 11-16-2006, 02:27 PM
