586,329 active members*
4,794 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > corrupt offset table
    Aug 2007
    29
    Exclamation corrupt offset table
    Got not one, but two 6030s with a gremlin.The offset value (fixture or tool) will, without anyone's help, place a < symbol where a decimal point was. There isn't even a key to enter that on the keyboard.Got a .25 hole in a fixture where there shouldn't be, because it will even happen while running. Anybody?
    Aug 2007
    29
    Re: corrupt offset table
    An update to this 'gremlin' is that the < symbol only appears (when it does) after the number '2'. It may leave some offsets containing a 2 alone, but others it will immediately follow. The decimal point is still there. Example - 2<.032. Any help ?
    Jun 2008
    51
    Suggestions:
    - Reinitializing the memory.
    - Remove and re-seat the memory expansion board several times to clean the contact pins.
    - Clean the processor board back plane pins with a pencil eraser.
  1. Corrupt programs?
    By Most in forum Haas Mills
    Last Post: 04-03-2014, 01:22 PM
  2. V23 corrupt
    By FUBAR62172 in forum BobCad-Cam
    Last Post: 04-16-2012, 03:08 AM
  3. corrupt files on 18i-mb
    By ikennedy in forum Fanuc
    Last Post: 11-21-2011, 11:41 PM
  4. Corrupt Software
    By ericwaa in forum Milltronics
    Last Post: 10-08-2009, 10:30 PM
  5. WTH Corrupt fixture Offset!?
    By DareBee in forum Fadal
    Last Post: 07-15-2005, 03:11 PM
