1998 Haas VF0
The mill just sits there no alarm no movement ?? I try'ed single blocking through the program to see if i could spot the error, but it single blocks through it perfectly doesn't stop, alarm or fault just keeps moving...
I did notice if i run the program after comp has passed on single block it runs fine, so i thought that might have been an issue and made my lead in larger.. and then noticed that it stops on the the first G3 line..
I tried running the same program but machining out several 3/8 dowel holes and it runs perfect... but the minute i try to machine this odd hole ( .440" ) 11.176mm it just stops and refuses to continue..
here is the Gcode if anybody can help me it would be appreciated!
O02627
(REWORK .440 BORE)
(T3| 1/4 FLAT ENDMILL|H3|D3|TOOL DIA. - 6.35|WEAR COMP)
N1 G21
N2 G0 G17 G40 G49 G80 G90
N3 T3 M6
N4 G0 G90 G54 X-140.826 Y-85.868 S7500 M3
N5 G43 H3 Z50.
N6 M8
N7 Z5.
N8 G1 Z2. F600.
N9 G41 D3 X-138.543 Y-90.047 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
N10 G3 Z1.6 I-1.157 J2.117 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
N11 Z1.2 I-1.157 J2.117
N12 Z.8 I-1.157 J2.117
N13 Z.4 I-1.157 J2.117
N14 Z0. I-1.157 J2.117
N15 Z-.4 I-1.157 J2.117
N16 Z-.8 I-1.157 J2.117
N17 Z-1.2 I-1.157 J2.117
N18 Z-1.6 I-1.157 J2.117
N19 Z-2. I-1.157 J2.117
N20 Z-2.4 I-1.157 J2.117
N21 Z-2.8 I-1.157 J2.117
N22 Z-3.2 I-1.157 J2.117
N23 Z-3.6 I-1.157 J2.117
N24 Z-4. I-1.157 J2.117
N25 Z-4.4 I-1.157 J2.117
N26 Z-4.8 I-1.157 J2.117
N27 Z-5.2 I-1.157 J2.117
N28 Z-5.6 I-1.157 J2.117
N29 Z-6. I-1.157 J2.117
N30 Z-6.4 I-1.157 J2.117
N31 Z-6.8 I-1.157 J2.117
N32 Z-7.2 I-1.157 J2.117
N33 Z-7.6 I-1.157 J2.117
N34 Z-8. I-1.157 J2.117
N35 Z-8.4 I-1.157 J2.117
N36 Z-8.8 I-1.157 J2.117
N37 Z-9.2 I-1.157 J2.117
N38 Z-9.6 I-1.157 J2.117
N39 Z-10. I-1.157 J2.117
N40 Z-10.4 I-1.157 J2.117
N41 Z-10.8 I-1.157 J2.117
N42 Z-11.2 I-1.157 J2.117
N43 Z-11.6 I-1.157 J2.117
N44 Z-12. I-1.157 J2.117
N45 Z-12.4 I-1.157 J2.117
N46 Z-12.8 I-1.157 J2.117
N47 Z-13.2 I-1.157 J2.117
N48 Z-13.6 I-1.157 J2.117
N49 Z-14. I-1.157 J2.117
N50 Z-14.4 I-1.157 J2.117
N51 Z-14.8 I-1.157 J2.117
N52 Z-15.2 I-1.157 J2.117
N53 Z-15.6 I-1.157 J2.117
N54 Z-16. I-1.157 J2.117
N55 X-140.857 Y-85.812 Z-16.2 I-1.157 J2.117
N56 X-138.543 Y-90.047 I1.157 J-2.118
N57 X-140.857 Y-85.812 I-1.157 J2.117
N58 G1 G40 X-138.574 Y-89.991
N59 G0 Z50.
N60 M5
N61 G91 G28 Z0. M9
N62 G28 Y0.
N63 M30
Sincerly a confused young lad
