Thanks Mikelota! It has set B1, that´s the reason why was not working. Right know I´ve set M2 and it looks like is modifying the velocity for cuttingand and engraving.
felling really happy for your help!!
thanks!
thanks!
No problem :-)
Hi! i'm back, sorry for the long time…
now i start to better understand how to work with this machine but i'm not soo satisfied, i work with paper and the cutting velocity and precision are not good. Until 30 mm/s work is acceptable, if i must cut little word or object must decrease until 20-22 mm/s. With straight line can go to 38-40 mm/s. Someone has been successful to cut with precision at fast speed? Need to change all the machine?
Second problem, when cut paper become dirty (honeycomb reflect on the back) especially with white and light colors, i cut at 20% at 20-25 mm/s (paper 200-300 g/m2), i use wrong setting?
I have a k40 laser and have been running it successfully for a few months ,,, however intermitently the comms would drop between the laser and the PC.
Usually this resulted in an error which said something like (USB Device is not recognized or malfunctioned) or occasionaly Laser Machine is disconnected.
Last week it stopped working altogether and I continually get the (USB Device is not recognized or malfunctioned) Error
I have tried on several PC's Laptops etc with the same results.
My Laser uses the following Board ; Lihuiyu Ketai Gold 2014G
Attachment 280780
The Dongle is Orange coloured type (B)
I think I need to replace the board,,,,,,,,,,,,,,,,,,,
Where can I get one??,,,,How much is this gonna cost ?? Is there another solution??
Please help
Davy
HI Friends
I just bought from China 40x40cm working laser engraving machine with MOSHI software. But it is very lousy and not friendly and every time must switch of the machine. Not yet I have done any job with this machine. I would like to migrate from MOSHI to CorelLaser. Is this advisable or any other better choice ?
Thanks.
HI friend,
small laser engraver with MOSHI software for stamp engraving, not good now here in China, though it is cheap in price ,but many cusotmer after buy find it has many problems,
our company now have new kind mahcine satorm600 ,better than this machine and aslo good quality can engraving on stamp etc all materials. ,
storm600(600*400mm) 35w, air fan, air piupe, water pump,10cm up&down table etc :USD1200 FOB price
this machine now very welcomed by customers.
Attachment 286120
Quiven form gweike laser
skype: wkquiven
[email protected]
I set up everything on my laser cutter and for some reason the computer sees that the USB dongle is inserted but will not let me continue and I get an error message saying it isn't plugged in. Could it be a mistake? Do I need to buy a brand new USB dongle to troubleshoot this issue? Or is there a different way of seeing if the USB is working correctly? Thank you! #HELP
We'll I'll take a stab at this: First which program are you using? If it's laserDRW you need to enter the machine code off of the circuit board into the "file" then "device initialize" the "device id" box. The device id is the first line of letters/numbers on the little paper tab stuck to the board. Also in device initialize make sure you have the areas laid out at least big enough to accomodate your object. plug in dongle and usb cable to machine,turn on machine and it should connect?
If you are using a different (Moshi) program then I don't know.
