I AM TRYING TO PROGRAM A PART THAT IS 3.25 DIAMETER WITH A 5765. RADIUS ON THE FACE. WHEN I RUN THE BACKPLOT EVERYTHING LOOKS GOOD BUT WHEN I POST G CODE IT POSTS A STRAIGHT LINE MOVE INSTEAD OF THE RADIUS. IS THERE A PARAMETER SETTING IN MASTERCAM FOR A MINIMUM RADIUS THAT NEEDS TO BE ADJUSTED SO IT WILL POST CORRECTLY. MANY THANKS IS ADVANCE REALLY STUCK HERE ANY SUGGESTIONS ARE WELCOME :drowning:
