586,933 active members*
2,510 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Lathe - Bigger motor or bigger bore?
Results 1 to 10 of 10
    Jun 2008
    49
    Hi all,
    I'm looking at getting a small benchtop lathe for a variety of tasks, I've narrowed it down to either a Warco WM 280V or a Toolco 1130GV, I need your help to make a final choice though. They're the same lathe except for a few details, the Warco has a more powerful motor with greater speed range (1.5kW, 30-2500rpm vs 1.1kW, 50-1800rpm for the Toolco), but the Toolco has a larger through spindle bore (38mm vs 25mm). Price is the same too so cost isn't a deciding factor.
    This is going to a be a general purpose lathe with no specific jobs in mind, anyone got an opinion which feature would be preferable?
    Thanks for any help
    Feb 2004
    1311
    Re: Lathe - Bigger motor or bigger bore?
    It really depends. There is nothing more frustrating than not having a large enough bore. But then again, there is nothing more frustrating than not having enough power.
    Consider this: you can replace a motor/drive train for more power but you can't easily enlarge the bore.
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Aug 2008
    962
    +1 for larger bore on a general purpose machine ..
    Dec 2004
    1865
    Bigger bore. You can always upgrade the motor.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    1943
    Another vote for larger bore.
    I agree with all the above posts. I loved my 7x12 mini lathe but quickly got tired of the tiny bore.
    Jun 2008
    49
    Then it's settled, bigger bore it is. Thanks guys
    Feb 2004
    1311
    That's so booorrriiinnngggg!
    Aug 2006
    1602
    Quote Originally Posted by Hamzter View Post
    How about the Warco WM290V - it is more pricey, but seems to have both a 38mm bore and a 1.5kW motor...
    Jun 2008
    49
    Quote Originally Posted by digits View Post
    Now that you mention it, once you add on a stand and DRO, it's pretty much the same price as a 280V, would make sense to get the 290V then, best of both worlds
  1. CNC bigger Grizzly lathe - anybody?
    By Spinnetti in forum Mini Lathe
    Last Post: 02-06-2008, 12:41 PM
  2. bigger motor runs, little ones don't...
    By killer_cobra in forum Stepper Motors / Drives
    Last Post: 04-01-2007, 02:30 AM
  3. Modifying spindle bore bigger
    By asuratman in forum Mechanical Calculations/Engineering Design
    Last Post: 02-18-2007, 01:01 AM
  4. My New Lathe; bigger/better
    By Stevie in forum Vertical Mill, Lathe Project Log
    Last Post: 02-02-2006, 04:32 AM
  5. New Bigger Stepper Motor!
    By widgitmaster in forum Stepper Motors / Drives
    Last Post: 10-26-2005, 01:39 PM
