586,308 active members*
3,736 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Is G540 able to power on a VFD
    I know that wired correctly, the G540 is able to control the speed, but is it able to power the VFD on/off as well?
    Nov 2012
    30
    Re: Is G540 able to power on a VFD
    Bob I'm not an expert at this since I have a post on getting my VFD working.
    But if you mean to disconnect/connect the power, like when you done using it but don't want to pull the plug out of the wall type thing, I think a relay or contactor off one of the OUTPUT terminals should do it.
    Well that's the only way I can see to do it. Hope someone can help you.
    Feb 2007
    711
    I think he means will the g540 control the vfd's forward/off terminals.
    It will, you will have to use one of the g540 outputs wired according to the g540 and vfd manuals.
    If your vfd supports it, it is much easier to use rs-485 communication to control on/off and speed.
  1. Using old 28v power supply for now with G540?
    By eodjeep2000 in forum Gecko Drives
    Last Post: 12-16-2011, 04:59 AM
  2. G540 power light ?
    By llamatrails in forum Gecko Drives
    Last Post: 09-14-2010, 12:53 AM
  3. Which power supply for G540?
    By forrest39 in forum Benchtop Machines
    Last Post: 12-10-2009, 10:12 PM
  4. G540 Power LED
    By SteveDH in forum Gecko Drives
    Last Post: 10-20-2009, 12:30 PM
  5. Best Power Supply for the G540
    By Jason Marsha in forum Gecko Drives
    Last Post: 05-26-2009, 02:38 PM
