586,133 active members*
3,938 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Having problems with spindle speed set to 0
Results 1 to 3 of 3
    Sep 2010
    10
    trying to run an engraving program for the first time using a diamond drag. The spindle should be turned off for this so I put S=0 ....trying to run this on a Haas TM1P if that matters....
    this is the program:
    O4811 (MC blades logo engravingtest)
    N1G40G49G80
    (Engraving)
    N2(Tool Diameter = 0 Length = 90 )
    N3G21T10M6
    N4 S0M3
    N5G90G0X95.758Y-14.284G54
    N6G43Z10.H10
    N7G54
    N8 G1Z-3. F100.
    N9 G17
    N10 G03X90.758I-2.5J0. F200.
    N11 X95.758I2.5J0.
    N12 G0Z10.
    N13G00 G91 G28 Z0.
    N14G28 Y0.
    N15M30
    Just trying to engrave a small circle as a test...however I get the error message :
    "Range error" with the cursor on line N4
    Any ideas to solve this?
    thganks in advance!
    Jun 2007
    3757
    Re: Having problems with spindle speed set to 0
    Why select M3 at all? You did want the motor stopped. Just comment out or delete N4 block (not a line. A block, they are called)
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Sep 2010
    10
    c
  1. Problems with spindle speed control
    By JamesHamilton in forum Phase Converters
    Last Post: 07-22-2012, 11:48 PM
  2. Lathemaster 9X30 spindle speed problems...
    By eartaker in forum Mini Lathe
    Last Post: 02-20-2011, 08:39 AM
  3. Spindle speed problems
    By dwessels in forum Benchtop Machines
    Last Post: 03-30-2009, 11:19 PM
  4. Problems with Hurco VMX 30 High speed spindle
    By csjtcooky in forum HURCO
    Last Post: 12-03-2007, 03:16 PM
  5. KM5P spindle speed problems
    By bgmnn in forum HURCO
    Last Post: 10-04-2007, 03:12 AM
