586,096 active members*
3,876 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 380v spindle on 460v? using vfd
    Feb 2005
    28
    I have an HSD spindle salvaged from a pile of surplus, rated for 380v 100-300hz. I only have 230v 3ph and a 460v transformer available. VFD is rated 380-480v and will supply the correct freq range.
    On a fixed hz motor this should work if v/hz ratio is the same but with a vfd can I run 460v to the motor(380v rated) and maintain (or shift) the freq operating range?
    I cannot find a 380v transformer locally or reasonably priced, the other option available would be buying a 32v buck transformer to bring it down to 428v closer to the 10% tolerance.
    24221
    Re: 380v spindle on 460v? using vfd
    In many VFD's the voltage of the motor can be set, see if it takes 380 as the motor plate voltage.
    Al.
  1. Chinese Spindles 240v or 380v ?
    By Litemover in forum DIY CNC Router Table Machines
    Last Post: 06-05-2013, 11:38 PM
  2. 460V 60Hz Servomotor on 380V 50Hz
    By Jerre122 in forum Servo Motors / Drives
    Last Post: 08-01-2012, 11:11 PM
  3. What to do with a 460v 3-Phase Motor?
    By Mrs.B in forum Phase Converters
    Last Post: 04-26-2011, 12:20 AM
  4. Need Help! 5HP motor 460V to 230V?!
    By diyengineer in forum CNC Machine Related Electronics
    Last Post: 10-25-2010, 12:08 PM
  5. Running 440V VFD with 380V
    By Khalid in forum Phase Converters
    Last Post: 08-20-2010, 05:18 PM
