586,882 active members*
4,028 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Oi-T removed battery with power off, now code 351 alarm
    Oct 2014
    Hi all, I have a Fanuc Oi-T control. the battery was removed with power off, now code 351 alarm is preventing any movement. Can someone point me to what needs to be done to correct this fault? Thanks for any help
    Jan 2011
    350
    Re: Fanuc Oi-T removed battery with power off, now code 351 alarm
    Reload your RAM backup.
    Insert your PCIMA card into the slot with the RAM backup.
    While booting, press the two right-most menu keys.
    Select 7. SRAM data backup.
    Then select 2. SRAM restore.
    Everything should be loaded back as before your memory was corrupted by lack of battery.
    Oct 2014
    Quote Originally Posted by botha.y View Post
    botha.y - Thank you for the quick reply. I'm not clear on what you said though. What do you mean by reload the RAM backup, i was lead to believe I had to reload parameters manually.
    Jan 2011
    350
    You could reload you parameters from a parameter text file, your programs from a programs text file, and finally your diagnostics from a diagnostic backup text file, this might be enough to solve your memory corruption that you say you got when you had no battery with machine power off.
    Still, I strongly recommend to reload everything from a working RAM file backup that would have been made while the machine was fully functionning, or get one from the machine OEM if you didn't make one.
    Hope that's clear enough.
    Oct 2014
    Thanks for your help. Gonna give it a try tonight.
  1. Z ALARM With drives removed
    By bbrreid in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2014, 12:40 PM
  2. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
  3. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  4. Replies: 12
    Last Post: 09-26-2010, 06:37 PM
  5. Replies: 2
    Last Post: 07-17-2007, 04:19 PM
