586,477 active members*
1,908 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Master Cam x6 . need help
    Oct 2010
    26
    Hello,
    I am having problem with the programs which are made in master cam x6 for wire machine. I was wondering if is possible to make programs on two decimals instead of four. If is possible, what I need to change. I am asking because I could not find it in the program. I could find but it is only related to drawing.
    Could someone tell me how to do it, please it is urgent. I am using wire machine - default settings.
    I suppose I need to change some values in MPWFANUC.pst part of code where word decimal is mentioned
    # Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
    #Format statements
    fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
    fs2 2 0.5 0.4 #Decimal, absolute, 5/4 place
    fs2 3 0.5 0.4d #Decimal, delta, 5/4 place
    #Common format statements
    fs2 4 1 0 1 0 #Integer, not leading
    fs2 5 2 0 2 0l #Integer, force two leading
    fs2 6 3 0 3 0l #Integer, force three leading
    fs2 7 4 0 4 0l #Integer, force four leading
    fs2 9 0.1 0.1 #Decimal, absolute, 1 place
    fs2 10 0.2 0.2 #Decimal, absolute, 2 place
    fs2 11 0.3 0.3 #Decimal, absolute, 3 place
    fs2 12 0.4 0.4 #Decimal, absolute, 4 place
    fs2 13 0.5 0.5 #Decimal, absolute, 5 place
    fs2 14 0.3 0.3d #Decimal, delta, 3 place
    fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place
    fs2 16 1 0 1 0n #Integer, forced output
    # These formats used for 'Date' & 'Time'
    fs2 18 2.2 2.2lt #Decimal, force two leading & two trailing (time2)
    fs2 19 2 0 2 0t #Integer, force trailing (hour)
    fs2 20 0 2 0 2lt #Integer, force leading & trailing (min)
    Aug 2012
    63
    Re: Master Cam x6 . need help
    I have done this before but can not remember exactly how for sure. It might be best to post your question on emastercam.com.
    May 2012
    180
    You should find a fmt x and a number. That number then relates to the fs2 data...
    Should be as simple as changing the values behind x y and z fmt.
    Dec 2008
    3110
    Quote Originally Posted by Bm150 View Post
    Right area.....NC output Variable Formats
    Not that simple,
    - you have only mentioned the absolute axes,
    - what about the incremental ones, arc centres, radius
    - does changing the number of decimals affect the arcs centers in regard to tangency of joining geometry ?
    It may be easier to alter the fs2 statements that are linked to the "NC output Variable Formats"
    old
    new
    fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
    fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
    .....now 4 decimal inch, 3 decimal metric for anything that calls up #2 or #3 formatting
    What is your problem with the machine ?
    - did it run OK using a X5 post ?
  1. PCB Master
    By Antonio Arguijo in forum Fanuc
    Last Post: 03-07-2013, 06:53 PM
  2. Master Cam X2
    By Eric MFG in forum Mastercam
    Last Post: 11-25-2009, 12:54 AM
  3. master cam x4
    By stk2008 in forum Mastercam
    Last Post: 10-02-2009, 08:38 AM
  4. master cam x
    By frankg521 in forum Machines running Mach Software
    Last Post: 10-31-2007, 01:10 PM
  5. How well does master cam
    By johnm in forum Mastercam
    Last Post: 06-02-2003, 05:06 AM
