586,385 active members*
3,330 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > THE MACHINE NEVER FINISH TO START UP
    Jul 2013
    4
    HELLO GUYS.
    I HAVE A PROBLEM WITH OKUMA MACHINE, MY BOSS BOUGHT A DOUBLE COLUMN MCR-BII IN JAPAN, THIS MACHINE IS USED,SO WHEN I TURN ON THE MACHINE, IT NEVER FINISH TO START UP
    SO I TRAY TO LOAD THE SOFTWARE BUT ARE DAMAGE THE DISK 4 AND 7 , I`M FINDING HELP IS IT POSSIBLE TO GET THIS SOFTWARE FOR THIS MODEL
    THE BUILD YEAR IS 1999. CONTROL OSP U100 AND THIS MACHINE HAVE ATTACHMENT SPINDLE.
    THANKS A LOT.
    Dec 2008
    3111
    Re: THE MACHINE NEVER FINISH TO START UP
    Turn your CAPS LOCK OFF, & stop yelling
    Quote Originally Posted by alvaro trejo View Post
    SO WHEN I TURN ON THE MACHINE, IT NEVER FINISH TO START UP.
    More info required,
    - Control ?
    - any alarm message.....alarm number AND full description of the top 2 lines ( picture is good )
    Do you have the pink ALARMS & ERRORS manual for that control ?
    THE BUILD YEAR IS 1999. CONTROL OSP U100 AND THIS MACHINE HAVE ATTACHMENT SPINDLE..
    silly thing to do if you don't know what is the cause...it might be hydraulic pump, air supply, etc.....not even related to the software
    A software re-load may only be needed if battery needed replacing ( done incorrectly), or memory, board etc is damaged
    Jul 2013
    4
    I`m sorry friend. I don`t told you.
    the baterry is dead and the memory was clean.
    so for this reason I need to load the software
    Jul 2013
    4
    I`m sorry friend. i don`t told you.
    the battery is dead and the memory was clean
    thank`s
    Aug 2011
    2517
    First thing you MUST do is get a good floppy set for your machine and load it. Contact Okuma. There is no other way.
  1. Best Practice (start and finish)
    By mountaindew in forum Tormach Personal CNC Mill
    Last Post: 05-04-2015, 04:05 AM
  2. HELP: PCB quality degrades from start to finish
    By psychoul in forum PCB milling
    Last Post: 01-22-2012, 06:17 PM
  3. Start to Finish help. What laser engraver will do the job?
    By 2A-TB@ThePatch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2009, 02:09 AM
  4. Paneling question start...finish
    By abelloise in forum ArtCam Pro
    Last Post: 12-03-2007, 06:09 PM
  5. PCB routing from start to finish
    By Swede in forum CNC Machine Related Electronics
    Last Post: 01-30-2004, 01:20 AM
