586,129 active members*
3,076 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Toolchanger commands for Mach 3 Turn
    Sep 2014
    I have a question for someone with more experience. I am using Mach3 software on a lathe. When I issue a normal tool change command (M6 T3), it does not send the tool position to the toolchanger (it returns Tool Position 0). If I enter M6 T0303, or M6 T300, it works. Is there any way to change this?
    Jun 2004
    355
    Re: Toolchanger commands for Mach 3 Turn
    T3 should change to tool 3 with offsets for tool 3, however it will depend on your M6 macro.
    Probably far better to post over the machsupport forum.
    Oct 2005
    1145
    In Mach3 turn the tool change wording is M6 T0101 The T0101 set s the tool # and Tool position.
    Just a thought, (;-) TP
    Jun 2010
    4256
    In fact, you can get away with just T0n0n if you want. I do.
    But as vamx549 said, you must repeat the number as shown. The first 0n selects the tool; the second 0n selects the row in the tool table for offsets. So T0n will get you tool n, but with tool 0 offsets. That can be embarrassing.
    Cheers
    Roger
    Apr 2006
    85
    in turning center tool change command is M6 T0101
    and in machining center tool change command is M6 T01.
    in lathe T01 will not work correctly in mach3
    thanks
    Jun 2010
    4256
    I think you have slightly misunderstood what is going on here.
    When you execute M6 T01 in a machining centre under Mach3, what you are really doing is executing M6 T0100. That is, you are changing to tool 01 with the offsets for tool 00 - which are probably zero all around. Provided you manually rezero the Z axis, or all your tool holders are identical, then no problems.
    Cheers
    Roger
  1. Mach 3 Turn
    By Grandad in forum Mach Lathe
    Last Post: 10-12-2012, 04:56 PM
  2. Mach 3 Turn update gone bad ~
    By daveupallnight in forum Mach Lathe
    Last Post: 05-08-2012, 06:57 PM
  3. bobcad v24 and mach-turn
    By ludovanginderen in forum BobCad-Cam
    Last Post: 01-29-2011, 01:42 PM
  4. cant get mach turn to run
    By panaceabea in forum Mach Software (ArtSoft software)
    Last Post: 12-10-2007, 02:56 PM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
