586,655 active members*
3,538 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > hurco hawk spindle drive problems
    Sep 2005
    26
    Hi all
    I was running my hurco hawk with no problems then when asked to in the program
    changed it to low gear for reaming.Then error popped up.Spindle drive overload,reset servo drives or spindle drive.
    They would reset but as soon as I pressed power on.Same thing Happened.
    attached picture shows what comes up.The leds come on with these codes then power is lost on all servo packs
    Any help would be greatful
    Attachment 251550
    Cheers Neal
    Jun 2008
    1104
    Re: hurco hawk spindle drive problems
    EPROM is corrupted or the CPU is faulty in the drive. You can copy all the parameters out of the drive and then re-initialise it to see if it is corruption and bring it back from the dead or if it needs a new CPU.
    Sep 2005
    26
    Thanks Mr Bloke
    Is this something easy-ish to to with a bit of research or is it a call to an hurco engineer
    Thanks again Neal
    Jun 2008
    1104
    It's not too tricky to do. It's a while since I've loaded parameters into one of those drives but they are easy enough to do. Where are you in blighty?
  1. Hurco BMC25 Spindle Drive Problems
    By James_c in forum Fanuc
    Last Post: 01-01-2014, 04:23 PM
  2. Hurco bmc25 spindle drive
    By James_c in forum HURCO
    Last Post: 03-22-2013, 12:57 PM
  3. HUrco BMC 30 spindle drive
    By xclr82xtc in forum Uncategorised MetalWorking Machines
    Last Post: 07-10-2010, 07:04 PM
  4. Hurco Yaskawa axis drive problems
    By bezelchuck in forum HURCO
    Last Post: 04-09-2010, 08:02 PM
  5. Problems with Hurco VMX 30 High speed spindle
    By csjtcooky in forum HURCO
    Last Post: 12-03-2007, 03:16 PM
