586,983 active members*
3,456 visitors online*
IndustryArena Forum > CAM Software > Esprit > New to Esprit and need to lie to software. Simulation
Results 1 to 7 of 7
    Jun 2014
    Good Morning Folks.
    We have recently switched over to Esprit for our general machining and mold building needs. For the most part I have the software figured out but I have one thing I am stuck on. When we program electrodes, we extract them in proe and save the whole thing as an assembly so when imported into Esprit the trodes are in the proper location and can be switched to the proper layers. Without reorientation the parts to align with the Global XYZ I set up different work planes and coords. for each trode. The problem is as some of you with experience know is that I can't simulate the tool path because it asks for another axis of revolution. I know I can fix this by rotating every part to the XYZ plane but would prefer not to since we like to have the electrodes in there natural location for the EDM operators on the floor to get the coords. from. Is there a setting I can change to fix this? Or a way to lie to the software but setting up a mock axis of rotation so I can simulate? If so how do I go about this? We don't have a 5 axis machine.
    Thanks in advance.
    Sep 2008
    18
    Re: New to Esprit and need to lie to software. Simulation
    In your machine setup just add A B and C axis. This should take care of all probable rotations. This will not effect NC code if you are just running 3 axis code, it will only change simulation.
    Jun 2014
    Thanks a lot Goooose. That works perfect.
    Apr 2012
    9
    I have a project requiring a integrex 300 post. We are waiting on a post to get done. I have a soildworks file of the part. Im willing to pay for the service .
    Possible ?
    Sep 2008
    18
    Quote Originally Posted by jim-c View Post
    Possible ?
    Are you looking to have the part programmed or a post for an integrex?
    Apr 2012
    9
    Quote Originally Posted by goooose View Post
    Both , actually . I have mastercam and HSM but no post for a new J300 mazak. I have some parts to program asap. My email is [email protected]
    In the process of getting Esprie, maybe.
    Sep 2008
    18
    email sent to you
  1. Looking for good CAM software,disappointed with Esprit Cam
    By javed08 in forum Uncategorised CAM Discussion
    Last Post: 02-28-2015, 06:44 PM
  2. Esprit 2009 Simulation
    By gunda in forum Esprit
    Last Post: 08-20-2013, 10:44 PM
  3. Post-to CNC Haas using Esprit software
    By carbajal in forum Esprit
    Last Post: 05-06-2011, 01:22 AM
  4. Esprit software no longer needed
    By nato31 in forum Esprit
    Last Post: 08-27-2008, 05:34 PM
  5. ESPRIT Mold new software?
    By surfsup in forum Esprit
    Last Post: 06-04-2008, 03:03 PM
