586,634 active members*
2,737 visitors online*
Thread: Interfacing
    Oct 2013
    17
    Interfacing
    I have been building a table for a little while now and am to the point that I was worried about. I have the table built, gantry rolling x/y/z using the CNC software but am stumped with interfacing the Longevity ForceCut42i/Proma/G540/Mach together. If anyone has any insight to do this it would be greatly appreciated. I will be posting pictures soon to detail the build itself but I do not have any pictures of it yet (I know I know....). I look forward to hearing back with any help that anyone is willing to offer.
    Oct 2013
    17
    Re: Interfacing
    This may be a better description of the issues I am having. I am planning on using my 42i as a cutter and it running along side a G540, Proma THC and Mach 3. I have the CNC plug that goes into the front of the machine and plan on using it. The wiring/soldering do not scare me but my concerns fall with what goes where after the plug is built. I understand how to wire up the divider from pins 6,7 to the Proma as well as running it to the G540 but I am a little unclear on setting up Mach 3 to understand what the Proma is telling it. I am also unclear as where to pins 8,9 go and 13,14. I know I need a relay (not sure which one) but I do not know what pins to run to it and what pins to run to the G540. I have a 48vdc 5amp relay (golf cart charger kind) but do not know if it would be appropriate/ok to use or not. I also don't think I need two but the drawing below shows two. Any help would be greatly appreciated as this is the last thing holding me back from having my machine up and running so I can cut racing parts for my RZR.
    Attachment 251580Click image for larger version.
ID:	251582Click image for larger version.
    Oct 2013
    17
    Re: Interfacing
    Some build pictures of the CNC plug, table, gantry, etc....Attachment 251776Attachment 251778Attachment 251780Click image for larger version.
ID:	251782Click image for larger version.
    Oct 2013
    17
    Re: Interfacing
  1. stepper interfacing
    By mrn in forum Stepper Motors / Drives
    Last Post: 02-10-2013, 09:54 PM
  2. Interfacing Stepper Motor
    By circuitx in forum Stepper Motors / Drives
    Last Post: 04-01-2011, 11:39 PM
  3. PMX1250 cnc interfacing
    By steve_p in forum Hypertherm Plasma
    Last Post: 09-24-2010, 10:22 PM
  4. Need help, regarding interfacing of NC Milling Machine with PC
    By iqtidar in forum DNC Problems and Solutions
    Last Post: 03-08-2010, 08:03 PM
  5. Makino Interfacing
    By Professorwiz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2005, 04:54 PM
