586,761 active members*
7,429 visitors online*
Results 1 to 3 of 3
    Jan 2012
    139
    Grouping Operations
    Hello,
    Is there a way to better organize the operations? For instance if you have more than one coordinate system on the same part (different setups on the machine) is there a way to group them in perhaps a folder or some other way? It can get real confusing when you have a complex part with many different setups.
    www.benchtopprecision.com
    | BF20/G0704 Belt Drive Kits | X2 Mini-Mill Belt Drive Kits |
    Oct 2007
    499
    Re: Grouping Operations
    Use the Split and Machine Setup functions (right click after you have highlighted a job in the Job Tree to see these functions). Split will force the creation of separate G code files and Machine Setup allows for different MAC's to be used together with different fixture setups.
    Jan 2012
    139
    Thank you sir, I figured there had to be a way. It would be nice if I could add a split before the first OP so I can group all of the first OP together. This will work just fine though. Thanks again.
  1. Tool path modification/(un)grouping/repair
    By curriergroh in forum MadCAM
    Last Post: 03-28-2012, 12:29 PM
  2. Grouping together Machine Setups
    By litza78 in forum CamWorks
    Last Post: 10-24-2011, 11:59 PM
  3. Replies: 9
    Last Post: 07-29-2010, 12:09 AM
  4. grouping cordinate systems with operations
    By camtd in forum GibbsCAM
    Last Post: 01-23-2009, 01:46 AM
  5. Grouping features
    By camtd in forum EdgeCam
    Last Post: 07-06-2006, 06:58 PM
