586,281 active members*
3,903 visitors online*
Results 1 to 20 of 20
    Oct 2012
    84
    Lasercad Shape cutting...Help Please
    Hi again guys...its the little Aussie Girl back yet again with a question.
    In the lasercad software it only allows you to draw SQUARE and ROUND shapes.
    My question is how do i import a shape into lasercad from another source and get it to CUT..Not engrave
    Im betting there is a simple answer to this....LOL
    BTW..i have software such as PRINT SHOP 22....PHOTODRAW...which i use a lot
    Can anyone help me
    Oct 2012
    84
    Re: Lasercad Shape cutting...Help Please
    Also is there any LASERCAD Tutorials available anywhere?
    This would probably help me better
    Jan 2008
    940
    Will Lasercad import dfx files I have Laserwork and I draw in Vectric Aspire or Autocad and export as a dfx then import into laserwork I can choose scan or cut in the settings
    Jun 2013
    45
    Hi Belin
    I use CorelDraw to draw all of my designs and then export to dxf and then import the dxf to Lascad.
    Oct 2007
    385
    I have Lasercad and I use Coreldraw x5. You can do any vector or rastor work directly in CorelDraw and then, by use of a button in the taskbar, you can send it over to lasercad where you can choose to either engrave the file or cut the file. Which, by the way, is an option in laserCad.
    Milt
    Nov 2012
    492
    if you go to rabbit usa you might find some help under tutorials
    Oct 2012
    84
    Quote Originally Posted by mondo50m View Post
    Milt
    Looks like I have no choice but to buy coreldraw x5.
    But corel draw products are so overpriced for their software
    Anyone got another less expensive option for software...If not then i guess im buying coreldraw x5
    Oct 2012
    84
    Ok Guys. I just purcgased corel draw x5.
    Now somehow I believe I can bypass using the current Lasercad restrictive software and simply connect corel draw to my laser. I only have a baby K40 laser but I have converted it to a DSP controller...
    If it is possible to use Corel Draw X5 direct...can you guys guide me on how to do it please..
    Remember Im a Girl.
    Im Blonde
    Im Australia
    So dumb the instructions right down for me please...LOL
    Nov 2008
    382
    hi belin
    I though you have squared away all your needs.
    you can import all files with extension : DXF, JPEG, BMP,AI, direct in to lasercad. but with JPEG,BMP, you can only engrave because this are picture, with DXF and AI if this are line drawings you can direct import them , mark the line you wana cut change the color to one from the bottom and set the cutting parameters .
    greetings
    waltfl
    Nov 2008
    382
    if you install lasercad after you have installed CorelDraw select the " lasercad for corel" from thinstall menue then you can send your file via ikon in CorelDraw directly to the lasercad software which you need in any case because only from there you can make choices for cutting, engraving, speed , power etc.
    greetings
    waltfl
    Nov 2012
    492
    did you read my previous post?
    Oct 2012
    84
    Quote Originally Posted by Bigbird48 View Post
    Yes I did. And I visited the Rabbit site but could not find any tutorials....
    Oct 2012
    84
    Quote Originally Posted by herby08 View Post
    greetings
    waltfl
    Thank You.
    So you mean I need to uninstall lasercad as I have it active at present.
    Then install Corel Draw X5 first. Then reinstall Lasercad to get Corel Draw to recognise Lasercad
    Am I understanding that correctly?
    Oct 2012
    84
    hi belin
    greetings
    waltfl
    Yes Thank You. But all I have at present is PHOTODRAW 2000 & Print shop 22 and neither have the facility to save as DXF or AI
    So I thought it best if I invest in the Corel Draw x5 as many of you guys are using it
    Nov 2008
    382
    hi belin
    yes that's correct.
    what version of lasercad do you have??
    here you can download the latest version and even a manual
    Download Center | Shenzhen Sinjoe Laser Technology Co., Limited
    greetings
    waltfl
    Oct 2012
    84
    hi belin
    yes that's correct.
    greetings
    waltfl
    Is this the WALT that helped me out many months ago???????
    Nov 2008
    382
    yes belin its me
    greetings to down under waltfl
    Oct 2012
    84
    yes belin its me
    Hi Walt
    See your PMs
    Nov 2008
    382
    I did reply already
    greetings
    waltfl
    Nov 2008
    382
    hi belin
    could you please respond to my email what I have send to your email address directly
    greetings
    walt
  1. Replies: 0
    Last Post: 07-03-2014, 07:00 AM
  2. Replies: 0
    Last Post: 03-04-2014, 06:50 AM
