586,609 active members*
3,437 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > CNC Lathe controlled with OLD! PC, can I change the PC and SOFTWARE??
Results 1 to 20 of 35
    Sep 2014
    51
    Hello I'm new here
    I just Bought an old Boxford 280 TCL, CNC Lathe.
    It's controlled with an OLD PC (using floppy discs, and running operating system: DOS- since its OLD)
    The PC is connected with a DB44 connection (looks like a standard parallel port but has 44 pins)
    My Questions:
    Does anyone know if I can connect another (more designated) kind of "control box" instead of a PC -just using the DB44 connection (more or less) ?
    2 Does anyone have any suggestions for how to get a more "up to date" kind of controlling (still using ISO G/M programming)
    - I want to be able to use CAD/CAM (But I guess that's "only" a matter of the right Post Processor?)
    - I'm working on a tool turret instead of the gang and on a C-axis.
    3 is this ^ only a matte of the "Controller" or do I need the replace/ change the electronics on the lathe itself?
    I hope I'm not asking too much, and if You could answer just one or some of the questions or give me some pointers I would Greatly appreciate it!
    I'm use to programming CNC lathes and Mill's but i'm pretty new to the electronics and the machines themselfs
    Oct 2010
    1189
    Re: CNC Lathe controlled with OLD! PC, can I change the PC and SOFTWARE??
    Hi is it using Steppers or servos ?
    I would Simply Start there i use on my lathe ncbox linuxcnc and triplebeast combination
    24223
    There are a few ways you can go, the PC you have is a ISA bus now legacy items, I would guess the DB44 is on a I/O card from one of the popular manuf of the time, if so it is ISA bus oriented and will not work with a later P.C.
    You may want to look at Mach3, Linux or kanalog for a new system.
    What type/make of motors and drives do you have? What was the old control s/w called?
    Al.
    Sep 2014
    51
    Hello again. sorry for my late response but, my lathe is currently stored kinda far away, so I don't have many details by now. It uses SERVO motors (don't know the brand/manuf) can I use triplebeast for that? that looks kinda easy?
    Oct 2010
    1189
    Hi if servo no but i found Granite devices which Drive the 1990 Year servos of bridgeport so Good Chance to Drive yours get the exact Data of your servos and if Stepper Steppers then we have a Look ,..
    Sep 2014
    51
    Al.
    Can't tell you much details since it's stored somewhere else for now... anyhow I'm not sure I know what you're asking?
    Sep 2014
    51
    thank you so much, I'll return asap when I have more details
    24223
    Quote Originally Posted by teglberg View Post
    Make or name of controller on the machine.?
    Al.
    Sep 2014
    51
    sorry still haven't got much info. I can see in the Datasheets that there's different versions of my machine, some fitted with DC and others with AC servos, but all of them are Closed Loop Servos. Is this enough knowledge for me to start pointing me in the right direction? (the machines runs on 380Vac, so I'm guessing It's fitted with the AC closed looped servos.)
    24223
    All servo's apart from steppers uses a PID closed loop system.
    You may be better off looking at a modern PC and using Mach3 as a start, there are more sophisticated add-on's such as Kflop etc.
    Keep as many of the power supplies as possible, there is probably quite a large part that has 1ph 120vac powered units.
    Keep the servo's if possible, and get step/dir drives, unless going Kflop and using the Kanalog card.
    Al.
    Oct 2010
    1189
    Hi i agree with al
    Adjust to a modern System with an actual pc (no matter if you use mach3 or linuxcnc ) but at the end of the day you need to control your servos so really get the real infos there
    that your machine runs with 380 V is nice but for sure that is splitted in the box to like 110 v several times.
    And you have a good chance to keep the servos
    I did similar on an bridgeport 412 from 1990 !! The servos are huge but finally i found an solution
    it is more like an open hart surgery keep as much of the existing machine but not too much -
    thomas
    Sep 2014
    51
    thanks for your reply. really appreciate all the help i'm getting here... can't wait to get the actual info so I can move along with this project! thanks again y'all!
    btw. totally agree, I'd really like to keep the servos and re-use as much as possible (only the parts that makes sence to re-use ofcause)
    Sep 2014
    51
    Got time to look at the machine. Hope You can help me some more with the new info.
    Can't find much details on the motors since the labels are gone.
    I google'd the electronics (DIGIplan DC30) and appears to be STEPPER controllers?
    Attachment 253446
    Attachment 253454
    so I'm guesing the motors for the axis' are steppers NOT servos?
    Attachment 253450
    the servo motor says "DCservomotor 8.5 NM" - that's worth keeping right?
    Attachment 253448
    there's a plate on the spindle with a lot of holes, looks to be some kind of encoder is that right?
    Attachment 253452
    The feedscrews (for the x-axis at least) isn't ballscrews - I'll check the accuracy when the machine's up 'n running and decide whether to change or not then.
    Can you tell me if my "info" seems about right?
    and where to go with my retrofit project from now
    want to control with mach3/similar with NEW PC
    want C-axis
    (and later on turret with live tools...)
    24223
    Appears to be a mixture of DC servo and stepper?
    The DC servo is most likely controlled by a ±10vdc analogue control, so if going step/dir you will need a different controller, if the stepper drives have step/dir input you maybe still able to use them.
    The spindle has a PG (pulse generator disc for a hall or optical sensor.
    If you want C axis control of the spindle (revolve around the Z) you will either need an auxilliary servo on the spindle or have a spindle capable of precise servo-like control.
    Especially using Mach.
    Al.
    Sep 2014
    51
    the DC servo is the spindle motor. Couldn't I just use that as is?
    for the C-axis I'll (later) use an auxilary servo. (and belt drive)
    for the axis' (X/Z) movement I might change to Nema34 stepper motors?
    - I can use the stepper drivers if it has step/dir and if not I'll change them too
    -right?
    ...anything I've missed?
    Oct 2010
    1189
    That is funny in my retrofit we kept even bigger sem servos at x y and z axis
    so if that is the spindle motor it is fine as well
    that can be easily done by VSE 160 granite device with 0.10 v interface
    and the axis x and z get us the spec of the motor or exchange it.
    so i would use linuxcnc
    triple beast bob board
    lead shine boards for the x and y steppers
    and the 0.10 volts for the spindle
    endstops and you are done
    you can get the encore signal from the servo back as a,b and z to make threading possible,
    And i guess it will be possible with mach3 but i stay away from windows in that case because you get all problems of windows and no benefit
    windows is not an real time system
    thomas
    24223
    That should be OK then if you can run the DC servo on the spindle, but what type of controller does it have?
    It may have had velocity control when a slotted type tach is used as shown, for true C axis positioning you will need an encoder on the final spindle shaft.
    Al.
    Sep 2014
    51
    I'll look at the spindle servo controller tomorrow..
    If the C-axis servo (the auxilary servo i'll attach) has an encoder woldn't that be enough? ofcause it won't be 100% accurate but close?
    (if) the axis' motors are steppers do i need to change them to Nema34 or can they somehow be converted to be used with mach3 (it all depends on the controllers?)?
    24223
    If the drives accept step/dir you should be able to use them directly with Mach?
    Presumably the motors and drives were matched and were up to the job on the machine.
    There are usually two ways to set up a C axis on the spindle, one is to have precise servo-type control of the spindle motor, complete with an encoder on the final shaft, or add an aux servo motor to the final shaft and use that when C axis positioning.
    Al.
    Oct 2010
    1189
    If you Look at the Sem picture the small Little box on the end of the Motor is the Encoder for my Project i spent Lot of Time in the Sem documentary ,...
  1. Find Software for Z zero after tool change
    By Mr.Chips in forum Calibration / Measurement
    Last Post: 01-12-2012, 03:31 AM
  2. Replies: 0
    Last Post: 06-11-2010, 07:59 AM
  3. I want to change my software ?
    By eng_semsem1980 in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-10-2007, 06:36 AM
  4. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
  5. Software change request
    By widgitmaster in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2005, 03:38 AM
