586,357 active members*
3,674 visitors online*
Results 1 to 7 of 7
    Oct 2013
    4
    tb6560 output voltage
    I have a serious problem. I use tb6560 controller 12v power adapter and NEMA 23 step motor (4,8V 3,0A). the engine makes a very strange noise, like whistling when stationary. what output voltage must come tb6560 stepper motor? I have now 12v
    May 2005
    1397
    Re: tb6560 output voltage
    That's a standard chopper whistle. Reduce the current setting. Oh, and get rid of that pile of junk 6560; it WILL fail on you eventually.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Oct 2013
    4
    Is it possible to be used only in the same step motors. Currently I use nema17 x, y, z axis and the a axis is nema23.
    May 2005
    1397
    Sorry, I don't understand the question?
    Oct 2013
    4
    i'm sorry my english is not good. i use google translators
    Do tb6560 controller must use only one type of step motors? can i use different stepper motors same time. (for example nema17 and nema23. )
    I have 3 pieces Nema17 12v and 1 pieces Nema23 4,8v.
    May 2005
    1397
    You can use only one stepper motor per driver. But you can use whatever size you like. If you have a driver board with 4 drivers on it, you can use different motors, one per driver, but different sizes on each driver on the board.
    But it's a REALLY bad idea to buy a board with several drivers on it. What do you do if you fry ONE of the drivers? You have to replace the entire board. Buy single drivers.
    Oct 2013
    4
    Thank you for the recommendations. I purchased four of the same NEMA 23 step motor, and now look forward to 24 volt power supply. but in hindsight I could really buy a single drivers. Thank you again for your advice. if I get a power supply, it will give you the results. BR
  1. how to check voltage on TB6560 board
    By hightrucker92 in forum Stepper Motors / Drives
    Last Post: 10-31-2013, 04:31 AM
  2. nema 14 stepper with TB6560 - voltage?
    By atair in forum Stepper Motors / Drives
    Last Post: 11-22-2012, 02:03 AM
  3. LPT PIN 1 Voltage Problem - (with TB6560)
    By Masterploxis in forum Controller & Computer Solutions
    Last Post: 05-19-2012, 06:47 AM
  4. Voltage & Hot Motors TB6560
    By r00tk1ll in forum CNC Machine Related Electronics
    Last Post: 09-02-2011, 08:17 PM
  5. TB6560 non constant voltage on X axis
    By telah in forum CNC Machine Related Electronics
    Last Post: 10-01-2010, 07:09 PM
