586,655 active members*
3,206 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Has anyone used one of these cheap handheld tachs?
    Jan 2011
    141
    Handheld Digital Photo Laser Tachometer Non Contact Tach Tool RPM Tester | eBay
    Wondering if its even worth that price. Need to calibrate my lathe index sensor and trying not to spend $200+.
    Carl
    24223
    Re: Has anyone used one of these cheap handheld tachs?
    I have one, they do a really good and accurate job, I have found.
    The only down side I found out is that if you leave the battery in the unit connected, it drains the battery quickly over a month or two, it must have an on button sensor that it active even when off.
    So the moral is to discconect after use.
    Al.
    Jan 2011
    141
    Cool, thanks Al.
  1. Looking for Handheld pendant
    By wickedboysap in forum Multicam Machines
    Last Post: 05-03-2011, 05:51 PM
  2. New handheld pendant for Mach3...
    By florins in forum Mach Software (ArtSoft software)
    Last Post: 11-16-2010, 04:53 PM
  3. add on a handheld control
    By cnc forum in forum Mechanical Calculations/Engineering Design
    Last Post: 08-25-2005, 01:09 AM
  4. Handheld Plasma Cutter with CNC?
    By Jim Stein in forum Waterjet General Topics
    Last Post: 08-28-2004, 03:41 PM
