586,096 active members*
3,611 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Connection diagram of lubricating pump
Results 1 to 1 of 1
    Jun 2008
    43
    Dear All,
    I have a milling OKK MHA800 use FANUC 15M,Last week the lubricating pump which use to lub the slide ways is not working.I bought one lubricating pump, maker :LUBE Coporation ,model :AMO-II-150S from eBAY ,unfortunatly its terminal connection for wiring is not identical with the old one and there are not the terminal connection diagram on the backside of the terminel cover.
    The terminal connection label : (from left to right) X Y G A B H J I K L M . I don't know the meaning of these labels. I trying to load the manual of the AM0-II-150S from THE LUBE website but the terminal connection diagram is quite difference my pump .
    Can anybody help me wiring the lub? I attach here the picture of the terminal connection
    Best regards
  1. DSP Controller connection diagram and setup
    By manolin in forum Laser Hardware
    Last Post: 02-19-2014, 04:09 AM
  2. Replies: 1
    Last Post: 04-30-2013, 10:52 PM
  3. Connection Diagram AMADA Fanuc
    By CNC Business in forum Want To Buy...Need help!
    Last Post: 02-06-2013, 05:31 AM
  4. 5 wire Sanyo Denki connection Diagram Needed
    By Fonfon in forum Stepper Motors / Drives
    Last Post: 04-06-2010, 11:52 AM
  5. Here Is A Connection Diagram I Drew.
    By ljoe1969 in forum Xylotex
    Last Post: 01-29-2004, 07:10 PM
