586,404 active members*
2,535 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Golden Sun Rotary table on FAnuc 21M
    Sep 2006
    222
    Hi!
    Control: Fanuc 21M
    Rotary Table : Golden Sun 251R
    Machine: Leadwell V40A
    Because of thunderstorm we did lost our parameters.
    I was able to recover all other but not 4th axis data, because that was installed later ( and i did not take backup when it was installed).
    Option parameteres should be ok, because machine was originally with 4th axis card.
    What parameter i should change ?
    Sep 2006
    222
    Re: Golden Sun Rotary table on FAnuc 21M
    Table: CNC-251R
    Year 2001/06
    Does anyone have datasheet for table ?
    Dec 2009
    957
    you need to read the code from the motor and than you need the parameters for that motor
    do you have already 4th axis displayed?
    Sep 2006
    222
    4th axis is displayed
  1. Replies: 0
    Last Post: 04-23-2013, 05:13 PM
  2. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  3. Replies: 0
    Last Post: 03-31-2010, 09:13 AM
  4. Rotary Table Interface on Fanuc OM/C: Do I need new firmware?
    By inthezone in forum CNC Machine Related Electronics
    Last Post: 10-16-2008, 08:30 PM
  5. Golden Sun rotary table
    By Green Button in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-26-2006, 12:52 PM
