Re: Stand alone controller driver
stand alone motion controllers exist but I don't know names and prices.
However I'd consider 2 alternatives:
The PLC itself - if it is just an indexing task you should be able to do this with the PLC and a regular stepper drive alone.
If speed is not an issue it just boils down to a timer generating a fixed number of step pulses and an output to control direction.
If speed is an issue you'd also need to program a ramp - a bit more work but still no big deal.
Stand alone automation stuff is usually expensive - I'd also reconsider a regular computer - they are cheap, especially if you also use e.g. LinuxCNC.
Christian
My CAM Software and CNC Controller: www.estlcam.com
