586,440 active members*
4,311 visitors online*
Results 1 to 5 of 5
    Oct 2010
    Laser tube wont start
    I bought recently chinese laser engraver IE1224 with 100W laser tube.
    When I started machine, water pump works, air compressor works, vacuum motors works, x and y motor works too. But laser tube wont start.
    Also on high voltage power suply i have some kind of test button which when pressed starts tube, and tube give light...
    Can someone help me please?
    Jul 2008
    776
    Move your topic in LASER ENGRAVING MACHINES FORUM. Provide more information - pictures of laser, tube, how tube is connected.
    Sep 2010
    i have no idea,but you must do as the introduction,laser tube is easy broke
    May 2005
    101
    May be water temperature sensor is not working.
    Re: Laser tube wont start
    Hello dear.
    Good morning to you.
    Jinan SUKE Science& Technology CO.,LTD specialized in laser machine with CE&FDA ceritificate with 6 years epxerience.
    About your questions, some reasone maybe , please check it one by one:
    1. To check water sensor system if ok or damaged? Connect P & G, if working well, that means, the water sensor damaged.
    2. To check the control box 6 terminal & 4 ternimal if any losen?
    3. To check soft setting, if any wrong about power, if 0% or 0 power.
    Hope you could tell me the answer after check .
    Please be free to contact me direclty.
    Email:[email protected]
    Skype:sukelaser08
    Mobile:0086-18668917435
    Sherry
    Quote Originally Posted by t3v4 View Post
  1. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  2. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  3. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
  4. cd-100 wont start
    By urbanimports02 in forum Novakon
    Last Post: 04-19-2010, 11:43 PM
