586,432 active members*
4,098 visitors online*
    Apr 2014
    Engraving Acrylic
    I have been trying to engrave Optix acrylic sheets and have not been able to get as good of a result as I would like. I am using a Onsrud 37-21 bit which is a 30 degree engraving bit with a .005" tip. I have played with feeds from 50 to 175 ipm but since the items are small anything over 100 ipm does not seem to make a difference. Also I have played with rpm from 7k to 12k. The best improvement was to make two passes with the first at .006" and the second at .008". Any ideas on how to get cleaner letters?
    Alan
    Aug 2012
    8
    Re: Engraving Acrylic
    I got the best result by spraying a constant stream on normal tap water on the engraving bit while cutting.
    210
    Use lube of soap and water
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
  1. Engraving acrylic, how to clean it?
    By Things in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-26-2019, 04:45 PM
  2. Cleaning Acrylic after engraving / cut
    By mochouinard in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2012, 01:13 AM
  3. Engraving (glass and acrylic)
    By fibonacci in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2010, 11:47 PM
  4. Acrylic engraving
    By ARTILLERO in forum Material Machining Solutions
    Last Post: 05-11-2010, 12:11 AM
  5. X2 Milling and engraving acrylic
    By Jay C in forum Videos
    Last Post: 10-10-2008, 05:47 AM
