586,138 active members*
3,602 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Setting VRef on original Xylotex 3-axis board
    Jul 2003
    92
    I have (I think) the original Xylotex 3-axis board from many (10?) years ago. It is old enough that it required 24 and 5 volt inputs, it didn't have a DC-DC to make its own 5V onboard. You can see in the enclosure I have adapted that I'm using a DC-DC to get the 5V.
    I ordered the board with a set of three motors. The motors are Powermax P21NSXC-LSS-NS-03. The motor tags say 1.75A on them. The kit came with cables. The motor connectors seem to have eight conductors, but the cables have four. It appears that the cable connectors have been configured so each of the conductors is wrapped around two sequential pins on the motor.
    I was studying my Xylotex manual, and it said the VRef should be set for motor current * 1.44. Well, I'm not sure I ever did this, it has been ten years after all. And I figured it probably came set form the factory. But nonetheless, I decided to check. I disconnected the motors and got my digital meter out.
    The way the board's pots are currently adjusted, X measures 3.33v, Y is 3.40, and Z is 3.39.
    But the motor current (1.75A), and multiplying that by 1.44 should be a VRef of 2.52?
    So the question is, am I set too high and should I decrease the VRef?
    I read that setting the current higher than the motor's rated value will only limit the motor's speed, it doesn't increase torque or anything. So no incentive to use a higher VRef?
    I also read that running higher current may cause a motor to overheat, but I don't think my motors have ever gotten particularly hot. But, I haven't run it a ton, either.
    But I could be missing something, so I thought I'd come here and ask before I make any adjustments.
    Thanks in advance.
    Re: Setting VRef on original Xylotex 3-axis board
    Are you sure the motors are wired bipolar series, and not bipolar parallel? If wired parallel, they'd be rated at 3.5 amps.
    If they are wired in series, then I'd lower the VREF to the recommended settings.
    My motors are 2.3 amps and I have my VREF set to around 3.0, I think (It's been about 6 years since I set it up.
    Mine is in the box with the PC, and I power mine with 5V from a HDD connector.
    Jul 2003
    92
    You are probably correct, Gerry. I'm trying to find documentation that would show me the way the Molex connector would be wired if series vs. if parallel, but google images isn't being kind.
    Is there an easy way to tell?
    EDIT: I actually started a new thread here: http://www.cnczone.com/forums/steppe...rs-wiring.html
    Because I figured I am really asking questions now about motors and not so much about Xylotex controllers.
  1. Current setting for TB6560 3-axis board (eBay)
    By leaveme in forum Stepper Motors / Drives
    Last Post: 01-27-2013, 11:19 PM
  2. Pop noise in 3 Axis Xylotex board
    By b7may in forum Xylotex
    Last Post: 01-25-2009, 03:15 AM
  3. Replies: 5
    Last Post: 04-11-2007, 07:47 AM
  4. Setting Vref---when?
    By monte55 in forum Xylotex
    Last Post: 10-25-2006, 01:55 PM
  5. Vref setting
    By CnC_BoY in forum Xylotex
    Last Post: 04-15-2006, 09:47 PM
