586,406 active members*
3,017 visitors online*
    Jun 2008
    18
    Roni Centur 35E Stuck in Feed Hold
    I've got a Romi Centur 35E with a Fanuc 0-TC control. Yesterday the machine stopped dead in the middle of a cut and alarm 408 was displayed. I called the machinery dealer and he told me to restart the machine. This cleared the alarm. I can move the axes with the jog keys or the handwheel. I can "home" the axes. I cannot, however, run any programs and the machine will not respond to any MDI commands. Diagnostic #121 indicates that the machine is in "Feed Hold". If you spin the chuck by hand, something in the electrical cabinet clicks and a "Not Ready" message flashes on the screen momentarily. I called both Fanuc and Romi, but they weren't able to help. Romi sent me the ladder diagram, but I have no idea how to read it. I've flipped the circuit breakers on and off, checked for loose connections, checked the oil level, and the operation of the door switch. Help! I'm already late with some deliveries and need to get this machine running.
    Nov 2004
    3028
    Re: Roni Centur 35E Stuck in Feed Hold
    Will it do rapid moves?
    Does it not do feed moves?
    Does it show a spindle speed? correctly? Usually if a spindle speed differs from command by 20 percent or more, it will not feed.
  1. feed hold with t-command
    By kwh in forum Auto Tool Changer
    Last Post: 08-23-2014, 12:58 PM
  2. Feed hold does it work?
    By stk2008 in forum Mach Software (ArtSoft software)
    Last Post: 06-15-2010, 06:06 PM
  3. Feed Hold
    By HelicopterJohn in forum Haas Mills
    Last Post: 04-25-2008, 03:57 AM
  4. Feed hold problem
    By kirby in forum Fanuc
    Last Post: 07-13-2007, 02:33 PM
  5. What should Feed Hold actually be??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 01-22-2006, 07:04 PM
