586,401 active members*
2,801 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Coolant recommendations
Results 1 to 10 of 10
    Jul 2008
    13
    Going to be getting a Torus Pro Servo mill shortly at work. For cutting aluminum, I've been using Kool Mist 78 with their misters on the small mills we have now. Has worked well up to now. But since the Torus Pro has the nice, new flood coolant chip tray, I'm going to need to get my feet wet with flood coolant (pun intended). Mostly cutting aluminum, R&D and light production quantities of parts, so ultimate machining performance and surface finish are not that important. Most important qualities are no rust, no bad smell, and long sump life. Did a few searches on the forums, and Hocut 795-B and Blasocut 2000 get good reviews. What do you guys recommend?
    Joe
    7063
    Re: Coolant recommendations
    I use RustLick WS-5050, mixed for a Brix of about 4.0. Works very well. KoolMist is terrible for drilling, which is the primary reason I switched.
    Ray L.
    Dec 2011
    316
    Look ay Blasocut 2000-CF. The CF stands for Chlorine Free specifically for aluminum. Have used for 3-4 years, no bad smells, sump grunge or any other nasty side effects.
    John
    Jul 2007
    675
    I use blasocut 2000. Love it. Mixed at 10%
    Sent from my A110 using Tapatalk
    Feb 2009
    6028
    We use blaso as well. Holds up well if we can keep the operators mixing it correctly and not put other crap in it. Once they decide to re-engineer the solution, goes bad in a day.
    Sep 2006
    1738
    TrimSol (will get the right number)
    Does occasionally leave some light rusting on my vise and table...
    Oct 2012
    342
    I'll put my 2 cents in too. I am running Rustlick Ultracut 380R. Attached is the data sheet. I picked it because it was rated for everything but magnesium and because my machine is in an minimally temperature controlled garage and the corrosion protection that Rustlick is known for. I have just been using it in a squirt bottle at 10% so far, because I don't have my coolant collection system done. But it makes a noticeable difference in surface finish and cutter chatter when I use it.
    Jul 2008
    13
    I read some people using Blasocut 2000 complained it removed paint from their machines. Anyone have that problem?
    Joe
    Dec 2011
    316
    No paint removal issues at all.
    John
    Dec 2004
    126
    I used blaser 4000 strong for years, good stuff but the price just keeps jumping up and up on it..... I switched to Trim E206 and it works just as good if not better for half the price,,, I watch enco 20% off sales and free shipping and order 6 buckets at a time. every machine that I stuck it in 2 1/2 years ago still has not been changed , its holding up GREAT and so is the paint . I would not change back even if they were the same price.
  1. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  2. Recommendations
    By barrigo in forum Gecko Drives
    Last Post: 01-02-2012, 11:29 PM
  3. CAM recommendations
    By Matt_NH in forum Uncategorised CAM Discussion
    Last Post: 02-23-2008, 07:42 PM
  4. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
  5. Need some recommendations
    By DragnsBane in forum CNC Machine Related Electronics
    Last Post: 01-31-2007, 10:11 PM
