586,423 active members*
2,883 visitors online*
    Oct 2012
    5
    help, rapid on my Mazak
    So I am having an issue, after a tool change my machine wants to rapid on the G1. When I run the program through or if I just start and run the tool before the one with the problem it cuts my groove at rapid feed. If I start from the tool with the problem then it works fine. The top line pasted is the taping cycle that is before the problem, you can see the codes through the tool change, feeding into the part and starting the profile. What really confuses me is starting at the tool chamge (#5) it works just fine but running through the program or starting at the tool just before I run into this problem.
    G98 G84 X-0.0049 Y-1.3572 Z-0.5 R0.1 P0 F0.0393
    X2.4001 Y-1.3842
    X0.9577 Y0.6485
    G80
    (OP2 MILL .12 SLOTS)
    M9
    G28 G91 Z0
    G28 X0 Y0
    M1
    N14 T5
    M6
    G0 G90 G55 X1.02 Y-1.4369 M3 S6500
    G43 Z2.5 H5 M8
    G0 Z0.1
    G1 Z-0.025 F26.
    G2 X0.5428 Y-1.2602 I0 J0.7328 F32.5
    G3 X0.2431 Y-1.6012 I-0.1478 J-0.1723
    G1 X0.7915 Y-2.095
    Dec 2008
    3111
    Re: help, rapid on my Mazak
    Your previous tool was tapping a 1mm pitch thread,....... going by the feedrate, it was feed per rev ( G95 )
    - there is NO change back to feed per minute ( G94 ) ...so it is doing 26" per rev feedrate
    I suggest that at the end of EVERY tool that a G94 is stated ie on or after the G80 line.....sort of like a safety code
    this will stop (ID ten T) errors......(change ten to 10 )
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Replies: 9
    Last Post: 08-06-2014, 10:16 PM
  3. help me, anyone knows rapid cnc? jinan rapid tech cnc company
    By araoz in forum Want To Buy...Need help!
    Last Post: 05-09-2014, 04:51 AM
  4. Mazak Mazatrol M-2 Rapid
    By sve0019 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-26-2010, 12:33 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
