586,399 active members*
3,210 visitors online*
    Jan 2010
    11
    invalid switch states
    I just finished a job on my 1996 Bridgeport torq-cut 22 everything ran fine. I tried to pull the tools from the carousel for the next job and got the message (invalid switch states) I tried to boot it and noticed that when I home axes the carousel dose not rotate like it always has. I can rotate the carousel with the (index carousel) button but not with the (S,T,M,) function at the control. Also I can (pull/put back) the current tool in the spindle with no noticeable issues. Anyone seen anything like this?
    Thanx Lary Alvey
    Nov 2004
    164
    Re: invalid switch states
    I've received that error for two reasons. One, and the most likely, is if the proximity sensors that detect if the tool carousel is all the way forward or fully retracted is failing. I've had a sensor rattle loose and intermittently fail at detecting the position and also the previous owner had screwed a prox. sensor in too far so that it was acting as both the sensor and the stop for travel. Eventually the prox was beaten to death and failed.
    The second is when the machine sees a tool clamped and tool unclamped signal at nearly the same time from two small switches at the top of the drawbar pancake cylinder. This happened right after a spindle bearing and drawbar spring rebuild with 10.5 kN of force and the air pressure dropped enough during the air blast to trip the switch. This was solved by bumping up the pressure regulator a bit
    I'm betting the problem is the former rather than the latter in your case. You could look at the switch signals on the maintenance page or visually check for the indicator lights on the prox. sensors themselves to verify.
    Jan 2010
    11
    Thanx jmullet it was the carousel back sensor. Had a wad of nylon chips blocking its view.......................Lary
  1. What are the best CNC schools in the United States?
    By AndrewWK in forum Mentors & Apprentice Locator
    Last Post: 09-16-2021, 12:11 PM
  2. Bridgeport TC3 PM INVALID SWITCH STATES
    By forhire in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2013, 04:58 AM
  3. HELP - TlChg: Invalid Switch States
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 03-15-2013, 01:27 AM
  4. Shopping in the States
    By andy_ck87028 in forum Australia, New Zealand Club House
    Last Post: 10-26-2007, 08:02 AM
  5. In the States
    By Egar Twins in forum Community Club House
    Last Post: 02-19-2005, 01:43 AM
