I have been trying to figure out a problem with the servo drive in an Okuma LB 15. I has the Alarm 201-4 Z Axis Servo Amp 2E6. The LED on the Z axis servo amp for IOC-S is lit (Excessive current flow through transistor bridge - short, according to the maintenance book - oh boy, that tells me a lot.)The BL-D 50 servo amp was sent in and rebuilt on the advice of the repair tech. No change. I tried switching the X and Z servo amps and the alarm stayed on the Z axis and the same LED was lit. Servo amp ruled out as problem? I accessed the electrical connections at the Z axis servo motor and took resistance readings and compared them to the X axis servo. I also checked for continuity to ground and got the same thing on both. After studying the schematic, the only thing that draws current through the transistor bridge is the servo motor. Maybe it has a short that only shows when power is applied? I'm just wondering if any one else has encountered the same thing and what the fix was. Thanks.
