586,395 active members*
2,962 visitors online*
Results 1 to 5 of 5
    Sep 2005
    106
    Homing.. need help please
    I have done both upgrades to the machine, as well as changed PC's. But I kept my profile, so I am not sure why this isn't working, as it used to before the changes:
    When I home, the axis moves in the correct direction until the limit switch is activated. But they won't retract off the switch. Here are my screen shots:
    Attachment 250066
    Attachment 250068
    Attachment 250070
    Can someone please tell me what I've done wrong.
    Ray
    35538
    Re: Homing.. need help please
    What happens? Do the axis labels turn green to show them homed? Or do you get a limit switch error?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    106
    Gerry,
    I am actually using your 2010 screen, so I don't know. I am using these switches
    Hall Effect Sensor Module from nicegear - New Zealand's open source and VoIP hardware specialist
    They have a LED on board so I know they are working.
    I get a limit switch error in Mach. It won't back off the switch, and I can't cancel it with a reset. So I can't back it off manually either.
    Any help would really be appreciated.
    Ray
    35538
    Try setting a debounce of around 5000, and see if it helps. If it does, then you're getting noise on the switch lines, or your switches are triggering again as they are backing off the switch.
    Gerry
    Sep 2005
    106
    Thanks Gerry, I will try that tonight.
    Ray
  1. Replies: 13
    Last Post: 06-25-2014, 02:21 PM
  2. Homing
    By george1965 in forum DIY CNC Router Table Machines
    Last Post: 07-06-2012, 07:46 PM
  3. Homing
    By BSawyer486 in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2010, 03:49 AM
  4. Can't get through homing
    By ironworksdesign in forum Bridgeport / Hardinge Mills
    Last Post: 09-03-2009, 04:59 AM
  5. HRT 210 homing
    By JAVB in forum Haas Mills
    Last Post: 12-07-2006, 07:44 PM
