587,013 active members*
3,803 visitors online*
    May 2014
    Getting better results from Gweike roller rotary
    I just received a Gweike roller style rotary from Automation Technology. I picked that one because I will be doing mostly cutting on open cylinders so I thought it would be more suitable than the the kind with a chuck and cone. From just plugging it in a running it a little, I'm not sure it will work. It is easy for the workpiece to jump off of the roller, though I think I can help that by making a jig to fit inside and increase the weight. However I am also noticing a tendency for the piece to slide left and right as it turns. Is there anything I can do to insure the piece stays in position? Since I am not rastering, it will be moving back and forth a fair amount rather advancing 1 line at a time in one direction.
    Sep 2012
    212
    Re: Getting better results from Gweike roller rotary
    HI, Johnson,
    Yes, you can increase the weight a little. Any quesiton, please contact us.
    G.Weike Laser
    [email protected] [email protected] skype:melody.gweike
    May 2014
    My biggest question at the moment is how to keep the cylinder from shifting left and right as it rolls. It this affected by the alignment of the idler rollers to the motorized rollers? It's very loose on the slide, and there isn't a way to lock it down.
    Nov 2012
    492
    lets see a picture
  1. Milling Results Were Off - Why?
    By GregGleason in forum Uncategorised CAM Discussion
    Last Post: 03-12-2014, 10:04 AM
  2. rotary attachment roller or chuck
    By Micheal Donnellan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2014, 11:42 PM
  3. Help linear bearing masters! roller fell out of roller bearing!
    By DKSMW in forum Linear and Rotary Motion
    Last Post: 03-07-2012, 06:45 AM
  4. Why I don't get better results??
    By KSPATZ in forum MadCAM
    Last Post: 04-09-2011, 09:00 AM
  5. Roller Circle using Mate Roller Ball -Finn Power SG5
    By Morgadoleo in forum Uncategorised MetalWorking Machines
    Last Post: 07-12-2010, 05:11 PM
