586,354 active members*
3,264 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Power cabinet cooling concern.
    Apr 2003
    1873
    In side are two cooling fans but see no air intake and things are sewn up what appears to be pretty tight inside and the cabinet door rubber sealed.
    This seems wrong, am I missing something?
    Ken
    Mar 2010
    1852
    Re: Power cabinet cooling concern.
    You gave no make, model or year, so I can offer just general information.
    There are different systems used on these machines. On my 96 VF-2 it is a heat exchanger system that uses air passing over an aluminum heat exchanger unit and no air passes in and out of the actual enclosure. On my 97 VF-2, there is an external filter and air passes through it and into the actual cabinet then back out.
    You need to get us pictures, or better to describe the system. In any event, I'm sure Haas did what they wanted to do.
    Mike
    Apr 2003
    1873
    "In any event, I'm sure Haas did what they wanted to do. "
    As long as they did what they wanted is the same as doing what they should then all should be OK and as far as can be seen this has not been the source of any issues..
    This lack of any way (that was seen) to recirculate fresh cooling air inside the cabinet was simply an observation made these last few days when looking into why it would not boot.
    Ken
    Jun 2013
    1041
    If it were cooling of the cabinet causing your issue it would still boot. It takes time for the cabinet to heat up enough to cause failure or shut down. If it doesn't boot at all you have other issues.
    Ben
    Apr 2003
    1873
    Ben,
    Agreed, I wasn't implying it had a thing to do with the non booting, it was just noticed when looking into the booting issue.
    Ken
    Feb 2009
    311
    It does seem wrong but likely the fans are for localized cooling, like some specific parts. The total air space inside the cabinet is fairly large so that would be enough as long at the total amount of heat being dissipated isn't larger than what can be conducted away through the sides of the box.
    I think my TM-1 is the same way. I don't remember there being any significant circulation paths from inside to outside the enclosure.
    C|
  1. Replies: 2
    Last Post: 05-17-2014, 01:19 AM
  2. Hawk 5M Power Cabinet OverTemp
    By HurcoUser in forum HURCO
    Last Post: 02-13-2012, 04:21 PM
  3. Replies: 1
    Last Post: 05-07-2009, 04:01 AM
  4. Identifying usable components in a BP BOSS3 Power Cabinet
    By damae in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2006, 06:25 PM
  5. Cooling Fan Power
    By Nono in forum CNC Machine Related Electronics
    Last Post: 07-10-2005, 04:08 PM
