586,894 active members*
4,297 visitors online*
Results 1 to 15 of 15
    Aug 2007
    22
    TNC 370 Postprocessor
    I'm looking for Heidenhain TNC 370 3 axis Post Processors for Mastercam X7 or maybe earlier versions wich I can upgrade
    Gonna use it to my Bridgeport VMC
    Re: TNC 370 Postprocessor
    i have a tnc 355 iso post processor for 3X mill and it works perfectly ( thanks to BM 150 )
    All what you have to do is to change the first two lines
    N110 G21
    N120 G0 G17 G40 G49 G80 G90
    by
    N110 % ''number of the program'' G71
    N120 G0 G17 G40 G90
    and the end
    N460 M5
    N470 M30
    By
    N460 M2
    just fix the arc center type to absolute and the arc breaks to don't breaks arcs , allow 360 degree arcs
    you had to close every mill drill cycles so the program will be little bit longer
    i thinks it is a temporary solution till you found what you need
    May 2012
    180
    Quote Originally Posted by azerty002 View Post
    N110 G21
    by
    N120 G0 G17 G40 G90
    and the end
    N460 M5
    N470 M30
    By
    N460 M2
    Do you want the first and last lines changed so it outputs with the need to change?
    Aug 2007
    22
    Thanks for the quick reply and good information!
    This will be tested, but is it not necessary with * .MMD and *.CONTROL files also to make it work?
    Those located in the folder CNC_MACHINES and usually called the same as * .pst file
    i will be thankful
    Apr 2013
    13
    For X7 TNC360
    Aug 2007
    22
    Perfect, thanks for that!
    seems to work fine but does not write the M06 line after the tool change, anyone know how to change it?
    May 2012
    180
    Quote Originally Posted by softail55 View Post
    Can do it if you wish?
    Aug 2007
    22
    Yes please
    May 2012
    180
    Sorry, owned my mouth before looking at the files. This post is at .psb file which cannot be edited as it is encrypted.
    Soz again.
    Apr 2013
    13
    Quote Originally Posted by Bm150 View Post
    Soz again.
    What needs to change?
    Aug 2007
    22
    Quote Originally Posted by Zub345 View Post
    seems to work fine but does not write the M06 line after the tool change?
    Aug 2007
    22
    Soz again.
    ok, I did not find anything either about the tool change in pst file so that explains why.
    Apr 2013
    13
    Give an example Nc code and MCX file, may I help you
    Feb 2015
    7
    hey.
    I have a postprocessor for 530i
    which cycles use your tnc330?
  1. postprocessor TNC 355
    By ccosma in forum EdgeCam
    Last Post: 12-11-2014, 09:53 AM
  2. Postprocessor
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-31-2014, 12:22 AM
  3. UGS NX6 POSTPROCESSOR
    By keyancnc in forum UG NX
    Last Post: 07-26-2010, 06:13 PM
