I'm looking for Heidenhain TNC 370 3 axis Post Processors for Mastercam X7 or maybe earlier versions wich I can upgrade
Gonna use it to my Bridgeport VMC
i have a tnc 355 iso post processor for 3X mill and it works perfectly ( thanks to BM 150 )
All what you have to do is to change the first two lines
N110 G21
N120 G0 G17 G40 G49 G80 G90
by
N110 % ''number of the program'' G71
N120 G0 G17 G40 G90
and the end
N460 M5
N470 M30
By
N460 M2
just fix the arc center type to absolute and the arc breaks to don't breaks arcs , allow 360 degree arcs
you had to close every mill drill cycles so the program will be little bit longer
i thinks it is a temporary solution till you found what you need
i will be thankful
Thanks for the quick reply and good information!
This will be tested, but is it not necessary with * .MMD and *.CONTROL files also to make it work?
Those located in the folder CNC_MACHINES and usually called the same as * .pst file
For X7 TNC360
Perfect, thanks for that!
seems to work fine but does not write the M06 line after the tool change, anyone know how to change it?
Yes please
Sorry, owned my mouth before looking at the files. This post is at .psb file which cannot be edited as it is encrypted.
Soz again.
hey.
I have a postprocessor for 530i
which cycles use your tnc330?
