586,443 active members*
3,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Mill changing head angle.....Pic Included
    Jun 2011
    6
    I am not able to change my head angle more than 8 Deg.
    I loosen the 4 bolts on the swivel portion but the bolt on the bottom stops it from turning.
    I thought it was a thread like the other head angle but it appears to be more like a cam. I turn it and the head will start to swivel for half a turn of the bolt. Then the other half turn of the bolt it forces it back.
    How do I get it to swivel more than 8 degs?
    Nov 2013
    152
    Re: Bridgeport Mill changing head angle.....Pic Included
    Hi Racin
    Slacken off the four horizontal bolts and keep turning the vertical bolt on the underside. It may be stiff to turn and that`s because the weight of the head
    working against the crank nut gear wheel. As a tip, don`t slacken them off too much as it puts more pressure on the crank nut. It will go , you just need to put some heave ho into it.
    Jun 2011
    6
    I am able to turn the vertical bolt but it will only move it approx. 8 deg, then while turning the bolt in the same direction the head stops moving then starts coming back to where it was originally. It feels like the bolt has a cam on it instead of a thread. The cam starts to move the unit then the weight comes off the bolt and if I continue I feel the weight coming back on and the unit is pushed in the opposite direction back to where I started.
    Does anyone have a diagram of this set up?
    Jun 2011
    6
    Still unable to get it to move more.
    I loosen the bolts so there was a 1/4 inch gap to try to get a look inside but nothing I can see stopping it.
    Does anyone know how this style works?
    The bottom bolt is dead centre and not on the side like a worm gear would be.
    Feb 2009
    311
    It sounds like maybe that's just how it is. It's possible the head is not intended to be tilted and the bolt is just a tramming aid.
    If you're work piece isn't too big why not set it up on an angle? Many times it's easier to do it that way than tilt the head.
    C|
  1. Noise in Bridgeport 2J head (audio file included)
    By daytrader in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2016, 07:03 PM
  2. Bed Mill with Bridgeport type head
    By native34 in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2014, 01:45 PM
  3. How to do a slot mill using right angle head
    By SatishNaik in forum News Announcements
    Last Post: 04-03-2014, 08:03 AM
  4. Looking for 30 degree included angle dovetail cutter, 3/16 or 1/4 shank
    By NegativeNines in forum Want To Buy...Need help!
    Last Post: 12-23-2013, 09:16 PM
  5. bridgeport mill head
    By serviceman in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2008, 01:46 AM
